JamieG Guest
Port B Output problem on PIC16F627A |
Posted: Fri Feb 05, 2010 9:01 am |
I have an RS232 controlled switch, the I/O pins control logic pins on some analog switches. An I/O pin goes Low when it receives a character on RS232.
I am having problems with 2 pins on Port B. RB4 and RB5 are constantly Low. I have been scratching my head for a while now. Can anyone help?
#include <16F627A.h>
#fuses INTRC_IO, WDT, PUT, NOLVP, BROWNOUT, NOCPD, NOPROTECT
#use delay(clock = 4000000)
#use rs232(baud=9600, xmit=PIN_B2, rcv=PIN_B1, BRGH1OK, ERRORS)
#define flash PIN_A4
#define A PIN_A1
#define B PIN_A0
#define C PIN_A7
#define D PIN_A6
#define E PIN_B7
#define F PIN_B6
#define G PIN_B5
#define H PIN_B4
int input, output;
void initialisations(){
//CCP_OFF;
//OSC_4MHZ;
set_tris_a(0b00000000);
set_tris_b(0b00000000);
setup_timer_1(T1_EXTERNAL|T1_DIV_BY_1);
enable_interrupts(INT_RDA);
#INT_RDA //RS232 receive data available
void isr_rs232(){
input = getc();
if (input == 'O'){ input = getc(); if (input == 'F')input = getc(); if (input == 'F')output = 0;}
else if (input == '1') output = 1;
else if (input == '2') output = 2;
else if (input == '3') output = 3;
else if (input == '4') output = 4;
else if (input == '5') output = 5;
else if (input == '6') output = 6;
else if (input == '7') output = 7;
else if (input == '8') output = 8;
switch (output) {
case 0:
output_a(11111111); output_b(11111111); break;
case 1:
output_low(A); break;
case 2:
output_low(B); break;
case 3:
output_low(C); break;
case 4:
output_low(D); break;
case 5:
output_low(E); break;
case 6:
output_low(F); break;
case 7:
output_low(G); break;
case 8:
output_low(H); break;
void main(){
initialisations();
output = 0;
//printf("\rAudio Switcher v1");
while(1){
restart_wdt();
output_high(flash);
restart_wdt();
output_low(flash);
//... and wait for rs232 interrupt
Wayne_
Posted: Fri Feb 05, 2010 9:35 am |
First of all I would not use "input" as a variable name as there is a function called input();
Secondly you can simplify your isr_rs232() routine.
input = getc();
if (input == 'O')
input = getc();
if (input == 'F')
input = getc();
if (input== 'F')
input = 0;
switch (input) {
case 0:
case 1:
case 2:
case 3:
case 4:
case 5:
case 6:
case 7:
case 8:
Lastly,
output_a(11111111); output_b(11111111); will not do what you expect until you add 0b to make your values binary.
output_a(0b11111111); output_b(0b11111111); |
Posted: Mon Feb 08, 2010 4:18 am |
Wayne_ wrote: |
Lastly,
I knew I'd missed something silly.
The reason I converted the input character to an integer is because I am yet to implement an option link which will offset the output.
I appreciate your help, thank you very much.
Jamie |
