Strcpy String to Structure Fails
John A.D.M
PostPosted: Tue Feb 02, 2010 4:30 pm     Reply with quote
Good Evening,
I'm writing a small program which acts a bit like a DOS environment on a PIC over RS232, however I'm encountering a very strange problem. I usually never ask for help but this time I cant figure why it does not work!!
Heres the code...
/*HEADER DEFINITIONS AND ENVIRONMENT VARIABLES*/
#include <16F648A.h>
#device PASS_STRINGS=IN_RAM // Work around for getting pointers to access constant strings
#fuses NOLVP, NOMCLR, INTRC, NOWDT, NOPROTECT, NOCPD
#use delay(clock=4000000) // 4MHz
#include <STRING.h>
#define max_label_len 11 // max name length for a command; 10 + 1(for null character)
#define cmd_len 5 // total count of commands
typedef void (*_Func)(void); // Define a function pointer as type: not supported otherwise
// INTERNAL COMMAND DATABASE
struct cmd_entry
   char name[max_label_len]; // represents the literal mnemonic of the action/verb
   _Func func; // pointer to function, _Func => void (*_Func)(void)
} cmd_db[cmd_len]; // structure stored in array
int command_counter=0;
void test(void)
// assign command to command database
void CmdLoader(char* funcname,_Func funcptr)
   // ERROR LINE BELOW, COMPILER WONT COPY TO STRUCTURE!
   strcpy(cmd_db[command_counter].name,funcname); // copy function name into structure
   cmd_db[command_counter].func=funcptr; // pointer to function is stored
   command_counter++;
   char usin[max_label_len]="test";  // "us-in" stands for user input
   CmdLoader(usin,test);
I have simulated the code often and pinpointed the problem down to a single line.
Why can't strcpy copy the string to the structure?
It works if I use
strcpy(cmd_db[command_counter].name,"test");
instead.
Thanks in advance. Whoever solves it gets a cookie...
PostPosted: Tue Feb 02, 2010 5:38 pm     Reply with quote
It would help if you would strip it down to a test program with only a
few lines of code. Get rid of all the comments and the function pointer
stuff, since that's not related to the strcpy problem. Use shorter variable
names if possible. Make it easy for us to look at the problem.
Post your compiler version.
John A.D.M.
PostPosted: Wed Feb 03, 2010 3:37 am     Reply with quote
Okay, fair point. I use MPLAB IDE 8.20 in combination with CCS PCB PCM PCH 4.087.
#include <STRING.h>
struct cmd_entry
   char name[11];
} cmd_db[5]; // structure stored as array
void CmdLoader(char* funcname)
   command_counter++;
   char string[11]="test";
   CmdLoader(string);
I programmed it on a PIC and used printf statements to show whats allocated. For some reason it wont copy a string stored under a variable into the structure...
Oh and thanks for your time.
PostPosted: Wed Feb 03, 2010 2:17 pm     Reply with quote
I agree there is a problem. It's possible that a work-around can be found.
I'll look at it more, later today.
John A.D.M
PostPosted: Wed Feb 03, 2010 3:34 pm     Reply with quote
At one point I had the thought it could be that strings are stored in the ROM, correct me if im false, and could not be accessed via pointer.
So I used #Device Pass_strings = In_Ram as I read in another post, but without success...
The significant part is that it works as "example" but not as a pointer. Btw, i checked whether the string is parsed to the function correctly and used it to copy from one string to another, no problem... its only structures.
John A.D.M.
PostPosted: Thu Feb 04, 2010 12:05 pm     Reply with quote
Any progress, any opinions.... im meant to demonstrate this on monday to investors :S
PostPosted: Thu Feb 04, 2010 4:44 pm     Reply with quote
I was able to make it work by using strncpy() instead of strcpy().
I tested the program below with vs. 4.087 in MPLAB simulator, and it
gave the following output:
String = test
String = ABC
String = DEF
String = 123456
String = Done
That's correct. Use strncpy() as shown below as a work-around.
#include <16F648A.H>
#device *=16
#fuses XT, NOWDT, BROWNOUT, PUT, NOLVP
#use rs232(baud=9600, xmit=PIN_B2, rcv=PIN_B1, ERRORS)
#include <STRING.h>
struct cmd_entry
char name[11];
}cmd_db[5];
int command_counter;
strncpy(cmd_db[command_counter].name, funcname, strlen(funcname));
command_counter++;
int8 i;
char string1[11]="test";
char string2[11]="ABC";
char string3[11]="DEF";
char string4[11]="123456";
char string5[11]="Done";
command_counter = 0;
// Load strings into cmd_entry structure.
CmdLoader(string1);
CmdLoader(string2);
CmdLoader(string3);
CmdLoader(string4);
CmdLoader(string5);
// Now display the structure contents.
for(i = 0; i < 5; i++)
    printf("String = %s \r", cmd_db[i].name);
John A.D.M
PostPosted: Thu Feb 04, 2010 5:36 pm     Reply with quote
Great Thanks.
I really appreciate your time.
Thats one strange bug though....
