muratmaman
At24c128/256 |
Posted: Sat Jan 30, 2010 4:37 pm |
I am using Pic16f886 and want to use At24c128 external epprom.
I am using i2c but could get any answer from At24c128.
I pull up scl and sda with 100k, and all address pins to gnd.
My compiler is PCM and Version 4.068.
#define EEPROM_SDA PIN_C4
#define EEPROM_SCL PIN_C3
#use i2c(MASTER, sda=PIN_C4,scl=PIN_C3)
void init_ext_eeprom()
output_float(EEPROM_SCL);
output_float(EEPROM_SDA);
BOOLEAN ext_eeprom_ready() {
int1 ack;
i2c_start(); // If the write command is acknowledged,
ack = i2c_write(0xA0); // then the device is ready.
i2c_stop();
return !ack;
disable_interrupts(GLOBAL);
output_a(0b00000000);
output_b(0x00);
output_c(0b00011000);
output_e(0x00);
set_tris_a(0b00000000);
set_tris_b(0x00);
set_tris_c(0b00011000);
set_tris_e(0x00);
init_ext_eeprom();
delay_ms(2);
while(!ext_eeprom_ready()); // could not pass this test
// my code does not come here
I used above code could not success. Anybody used to before At24c128. _________________ I have been developing pic and other microcontroller. I would want to share and get experiment form this site |
Posted: Sat Jan 30, 2010 5:11 pm |
Quote: | I pull up scl and sda with 100k |
1K is standard I2C pull-up, 10K will possibly work, 100K most likely won't. |
muratmaman
Posted: Sat Jan 30, 2010 5:23 pm |
FvM wrote: | Quote: | I pull up scl and sda with 100k |
Thanks for your comment. Before 100k I tried 10k but result was same.
Do you think my code is true? Do you have another idea ? _________________ I have been developing pic and other microcontroller. I would want to share and get experiment form this site |
Posted: Sat Jan 30, 2010 11:53 pm |
Use this driver:
Quote: |
c:\program files\picc\drivers\24256.c
Make a test program similar to the one shown in this link:
http://www.ccsinfo.com/forum/viewtopic.php?t=30346&start=10
Change the #define statements to use your own i2c pins.
Change the pull-up resistors to 4.7K ohms.
Don't use inline driver routines, as in your original post. Include the
24256.c eeprom driver with an #include statement, as shown in the link
above. Call the driver routines from main(). |
Posted: Sun Jan 31, 2010 4:14 am |
What processor?.
This affects whether you are using hardware I2C, or software.
Are you operating a 5v version, or a 3.3v version. What voltage is your system?.
Is the WP pin grounded as well?. Since you are trying to get an ACK, from a 'write' operation, I'm not sure this will be acknowledged, if the WP pin is high...
Posted: Sun Jan 31, 2010 4:55 am |
Quote: | Since you are trying to get an ACK, from a 'write' operation, I'm not sure this will be acknowledged, if the WP pin is high... |
It will.
Quote: | When Write Control (WC) is driven High, Device Select and Address bytes are acknowledged, Data bytes are not acknowledged. |
muratmaman
Posted: Sun Jan 31, 2010 7:32 am |
FvM wrote: | Quote: | Since you are trying to get an ACK, from a 'write' operation, I'm not sure this will be acknowledged, if the WP pin is high... |
It will.
Please find attached image file and get more detailed information about my design.
I am using Pic 16f886 and Vcc = 5v
also wp connected to GND.
http://www.zumodrive.com/share/3mXpYzE2Yz
I could not tried 24256.c driver and could not pull up 4.7k but I will try as soon as possible.
But I am intersting that 24c256.c driver and 4.7k pull up appropriate to At24c128/256.
Also I am using these configuration
#include "16f886.h"
#device *=16 ADC=10
#use delay(clock=8000000) // 8MHz Clock
Is it important to use internal oscillator with 8 Mhz or 4 Mhz ?
#fuses INTRC,NOWDT,NOMCLR,NOPROTECT,NOLVP,NOBROWNOUT,NOPUT,NOCPD, NODEBUG
// set up internal oscillator
setup_oscillator(OSC_8MHZ,0); //set oscillator to 8Mhz
Does it make sense ? |
Posted: Sun Jan 31, 2010 8:05 am |
It seems like the compiler is using software I2c by default. You can try with hardware I2C by adding
FORCE_HW to the #use i2c statement.
I don't see a particular problem with your code or hardware.
You should also mention the compiler version. |
muratmaman
Posted: Sun Jan 31, 2010 10:59 am |
FvM wrote: | It seems like the compiler is using software I2c by default. You can try with hardware I2C by adding
My compiler is PCM and Version 4.068. _________________ I have been developing pic and other microcontroller. I would want to share and get experiment form this site |
Posted: Sun Jan 31, 2010 11:28 am |
0=ACK.
In C, 0=true
So your function, returns ext_eeprom_notready (since you invert your ACK bit). Then you invert this again, so will wait if the chip _does_ acknowledge.....
muratmaman
Posted: Sun Jan 31, 2010 12:42 pm |
Ttelmah wrote: | 0=ACK.
In C, 0=true
I prepared my code according to your suggestion but result was same. My code could not pass below control. Could not read which I wrote.
write_ext_eeprom(0x01, 0xAA);
data = read_ext_eeprom(0x01);
if(data == 0xAA)
BlinkRed();
Beep(2000);
I do not understand what is different between hardware i2c and software i2c. I tried hardware i2c like FORCE_HW but my software is frozen.
Tomorrow I will change my hardware pull up resistor 100k to 4.7k.
Any other relevant suggestion ? |
muratmaman
Posted: Sun Jan 31, 2010 1:35 pm |
This is my latest code.
//main.h
#include "16f886.h"
#device *=16 ADC=10
#include "main.h"
#use fast_io(A)
#use fast_io(B)
#use fast_io(C)
#use fast_io(E)
#include <24256.c>
#define BUZZER PIN_C2
void Beep(int delay)
output_high(BUZZER);
delay_ms(delay);
output_low(BUZZER);
BYTE data;
output_a(0x00);
output_b(0x00);
output_e(0x00);
set_tris_a(0x00);
set_tris_b(0x00);
set_tris_e(0x00);
init_ext_eeprom();
delay_ms(2);
write_ext_eeprom(0, 0x55);
data = read_ext_eeprom(0);
if ( data == 0x55 )
Beep(50);
Posted: Sun Jan 31, 2010 2:17 pm |
Try a more simple program, as shown below. Also make sure you have
the correct connections:
Pin C4 on the PIC connects to the SDA pin on the At24c128.
Pin C3 on the PIC connects to the SCL pin on the At24c128.
The Vss pin (ground) on the PIC connects to the GND pin on the At24c128.
Also, notice the order of the first 3 statements. The #use delay()
comes after the #fuses. If you do it this way, the compiler will
automatically setup the correct oscillator configuration. Then you
don't need to use the setup_oscillator() statement.
#include <16F886.h>
#fuses INTRC_IO,NOWDT,NOMCLR,NOLVP,NOBROWNOUT,NOPUT
#include <24256.c>
delay_ms(delay);
output_low(BUZZER);
int8 data;
init_ext_eeprom();
if(data == 0x55)
Beep(500); // Beep once if data is correct
Beep(500); // Beep 3x if not correct
Beep(500);
Beep(500);
muratmaman
Posted: Sun Jan 31, 2010 2:37 pm |
PCM programmer wrote: | Try a more simple program, as shown below. Also make sure you have
#include <16F886.h>
#include <24256.c>
delay_ms(delay);
output_low(BUZZER);
int8 data;
init_ext_eeprom();
if(data == 0x55)
Beep(500);
Beep(500);
Thanks for your effort but software could not pass this line
In this line code frozen. _________________ I have been developing pic and other microcontroller. I would want to share and get experiment form this site
