18f1330 INT_RDA problem.
sf
PostPosted: Sat Jan 30, 2010 2:59 pm     Reply with quote
Hi, I'm trying to make this:
#include <18F1330.h>
#device adc=8
#FUSES NOWDT                    //No Watch Dog Timer
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES H4                       //High speed osc with HW enabled 4X PLL
#FUSES FCMEN                    //Fail-safe clock monitor enabled
#FUSES BORV20                   //Brownout reset at 2.0V
#FUSES PUT                      //Power Up Timer
#FUSES NOCPD                    //No EE protection
#FUSES NODEBUG                  //No Debug mode for ICD
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#FUSES NOWRT                    //Program memory not write protected
#FUSES NOWRTD                   //Data EEPROM not write protected
#FUSES NOWRTC                   //configuration not registers write protected
#FUSES NOEBTR                   //Memory not protected from table reads
#FUSES NOEBTRB                  //Boot block not protected from table reads
#FUSES MCLR                     //Master Clear pin enabled
#FUSES NOPROTECT                //Code not protected from reading
#FUSES NOCPB                    //No Boot Block code protection
#FUSES NOWRTB                   //Boot block not write protected
#FUSES BBSIZ1K                  //1K words Boot Block size
#FUSES FLTAA5                   //FLTA multiplexed on A5
#FUSES T1OSCA6                  //T1 oscillator pin on A6
#FUSES PWMPIN                   //PWM outputs disabled upon Reset
#FUSES HPOL_HIGH                //High-Side Transistors Polarity is Active-High (PWM 1,3,5 and 7)
   //PWM module high side output pins have active high output polarity
#FUSES LPOL_HIGH                //Low-Side Transistors Polarity is Active-High (PWM 0,2,4 and 6)
   //PWM module low side output pins have active high output polar
#use delay(clock=32000000)
#use rs232(baud=9600,parity=N,xmit=PIN_A2,rcv=PIN_A3,bits=8)
#include "main.h"
#define BUFFER_SIZE 32
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#int_RDA
void  RDA_isr(void)
   int t;
   buffer[next_in]=getc();
   t=next_in;
   if(next_in==next_out)
     next_in=t;           // Buffer full !!
BYTE bgetc() {
   BYTE c;
   while(!bkbhit) ;
   c=buffer[next_out];
   return(c);
   setup_adc(ADC_CLOCK_DIV_2|ADC_TAD_MUL_0);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
   setup_comparator(NC_NC_NC);// This device COMP currently not supported by the PICWizard
   enable_interrupts(INT_RDA);
   printf("\r\n\Running...\r\n");
               // The program will delay for 10 seconds and then display
               // any data that came in during the 10 second delay
   do {
      delay_ms(10000);
      printf("\r\nBuffered data => ");
      while(bkbhit)
        putc( bgetc() );
   } while (TRUE);
But the interrupt never "fired"........
There is any problem with this pic? can someone else try this code to see if is my mistake?
Thanks in advance.
SF
PostPosted: Sun Jan 31, 2010 12:09 am     Reply with quote
Post your compiler version.
