[SOLVED thanks]#INT_RDA executed once !
ELCouz
PostPosted: Wed Jan 27, 2010 11:39 pm     Reply with quote
Dear programmers,
I'm working on a big project with the dspic30f4013.
I've ran into an issue with the serial interrupt. It only fire once !
I've simplified the whole project to this simple test code.
#include <30f4013.h>
#FUSES FRC_PLL16,PR_PLL,NOWDT,NOPUT,NOMCLR,NOBROWNOUT
#use delay(clock=117920000)
#use rs232(baud=9600, UART1A, ERRORS)
#INT_RDA
void analyzepacket_isr(){
int8 inputchar;
inputchar = getc();
output_high(PIN_D3);
enable_interrupts(INT_RDA);
while(true){
delay_ms(200);
output_low(PIN_D3);
The led only goes high and then 200 ms after turns off never go high again and data still flowing to the pins !
I've tried to clear the interrupt still nothing but i know the pic is still _running_ (it catch my buttons press [not shown in this code])
I've read somewhere that i need to call getc (read the data) to clear the interrupt i don't know if its true but just in case i've left the getc part.
EDIT: tried with output_toggle same thing ! :(
EDIT2: PCWHD 4.104
Any ideas?
Thanks!
Regards,
Laurent
Here's my first visual theme for the CCS C Compiler. Enjoy!
bkamen
PostPosted: Thu Jan 28, 2010 12:32 am     Reply with quote
The interrupt is cleared by the interrupt routine (you don't see it, but invoking #int_xxx installs the CCS interrupt handler (provided you don't specify #int_global)).
The receive-buffer-full flag is cleared by doing the getc();
Consider adding "stream=comm" or some-such to your #use RS232 statement and then calling fgetc(comm); to narrow the program to get from that channel.
Also, UART1A? is that right or a typo?
So you have a scope? Consider toggling a pin high and then low inside your ISR to make sure it keeps firing after every RS232 char.
-Ben
ELCouz
PostPosted: Thu Jan 28, 2010 12:45 am     Reply with quote
I've copied this line from a example of CCS from EX_SISR.c (because i know this would works its an official example Smile )
#elif defined(__PCD__)
#include <30F2010.h>
#fuses HS, NOWDT, NOPROTECT
#use rs232(baud=9600, UART1A)
after further investigation i've found this somewhere in the forum
// UART1A specifies the alternate UART pins Pin_C13, Pin_C14
// use UART1 to sprcify UART for pins Pin_F3, Pin_F2
I'm on F3 and F2 pins
Now i've tried with UART1 and it work jeez i feel very sorry to not check this before posting !!!
Thank you ! Smile
Regards,
Laurent
