PIC24: ccs picc and printf
GLADKIH_UA
PostPosted: Mon Jan 25, 2010 2:23 pm     Reply with quote
Hello. I have problem. I'm using v4.103 for PIC24fj64ga002. And my problem:
float result;
printf(lcd_putc, "%f",result);
It's some part of my code. When my program come to line
and try do it then PIC is RESET. What I don't do right ? I use this function for PIC16f877A and don't have any problem. Please help me.
You will excuse me for the rough language. I am from the Ukraine.
FvM
PostPosted: Mon Jan 25, 2010 3:34 pm     Reply with quote
I can imagine at least two possible problems:
- any issues with your implemenation of lcd_putc(), e.g. involving access to non-existent memory. Does lcd_putc() work with other data types?
-a stack overflow, as dicussed in the forum before. Try to increase the stack by
#build(stack = 256)
Wayne_
PostPosted: Tue Jan 26, 2010 2:50 am     Reply with quote
Could also be WDT. Show your fuses and init code.
GLADKIH_UA
PostPosted: Tue Jan 26, 2010 10:57 am     Reply with quote
#build(stack = 256)
Thank you. all work oke'y when i try use #build(stack = 256)
FvM
PostPosted: Tue Jan 26, 2010 3:03 pm     Reply with quote
Seems like CCS developers will be the last to realize, that PCD default stack allocation is insufficient.
