ac34856
| Writing Structure to EEPROM reset_cpu() clears Data EEPROM |
Posted: Wed Jan 20, 2010 2:11 pm |
I wrote this program to test writing a data structure to the PIC
data EEPROM. It appears to work when reading / writing the
EEPROM with the user input menu but when the PIC is reset
via the menu the data is lost when its read from the menu.
Anyone got any ideas - I am completely baffled. It reads data from
EEPROM but reset_cpu() clears it again. Compiler version 4.09
// 18F4620-Setup-Write-V1.c
// Program to check writing setup structure to NVM
#include <18F4620.h>
#device PASS_STRINGS=IN_RAM
#device *= 16;
#fuses HS, NOWDT, NOPROTECT, BROWNOUT, PUT, NOLVP, NODEBUG, MCLR
#use DELAY(CLOCK=20MHz, RESTART_WDT)
#use RS232(BAUD=115200, XMIT=PIN_C6, RCV=PIN_C7, STREAM=COM1, RESTART_WDT)
#include <stdio.h>
#include <string.h>
#include <stdarg.h>
#include <stdlibm.h>
void init_structure_defaults_in_memory(void);
void clear_structure(void);
void read_eeprom_string( char *, int8, int8);
void write_eeprom_string(char *, int8, int8);
void load_setup_from_nvm(void);
void save_setup_to_nvm(void);
void erase_nvm(int16);
const char EMPTY[]={"**************************"};
const char CHANNEL[]={"Channel 1 Control Defaults"};
struct PID { char ident[sizeof(CHANNEL)] ;
float Kp, Ki, Kd ; // PID Gains
char is_setup ; //
} trx, *ptrx ; //
char buffer[sizeof(trx)];
char ch=0;
int16 counter=0, s_size;
ptrx = &trx;
s_size = sizeof(trx);
// Clear structure to check it loads ok on startup
trx.Kp=0; trx.Ki=0; trx.Kd=0;
strncpy(trx.ident, EMPTY, sizeof(EMPTY));
fprintf(COM1, "\r\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n\n");
fprintf(COM1, "=================[ CPU Reset ]=================\r\n");
fprintf(COM1, "\r\n Structure trx (size : %Ld), Kp=%f, IDENT=%s", sizeof(trx), (*ptrx).Kp, trx.ident );
trx.Kp=0; trx.Ki=0; trx.Kd=0; // Clear initialised structure
{ fprintf(COM1, "\r\nCount : %Ld, Struct Data : %f %f %f \n\r", counter++, trx.Kp, trx.Ki, trx.Kd);
fprintf(COM1, "\r\n 1. Save Setup to NVM");
fprintf(COM1, "\r\n 2. Load Setup from NVM");
fprintf(COM1, "\r\n 3. Initialise Setup");
fprintf(COM1, "\r\n 4. Erase NVM ");
fprintf(COM1, "\r\n 5. Clear Structure");
fprintf(COM1, "\r\n 6. Reset CPU ");
fprintf(COM1, "\r\n\n Enter a choice : ");
ch=getch();
switch (ch)
{ case '1' : save_setup_to_nvm();
continue;
case '2' : load_setup_from_nvm();
continue;
case '3' : init_structure_defaults_in_memory();
continue;
case '4' : erase_nvm(sizeof(trx));
continue;
case '5' : clear_structure();
continue;
case '6' : reset_cpu();
continue;
default : break;
void erase_nvm(int16 size)
int16 i=0;
fprintf(COM1, "\r\n Erasing %Ld bytes ", size);
for (i=0; i<size; ) write_eeprom(i++, 0);
void read_eeprom_string(char *array, int8 address, int8 max_size)
int8 i = 0;
*array = 0;
while(i<max_size) { *array=read_eeprom(address+i);
if (*array==0) { i=max_size; }
else { array++;
*array=0; }
i++; }
// Function: write_eeprom_string
void write_eeprom_string(char *array, int8 address, int8 max_size)
int8 i=0;
while(i < max_size)
{ write_eeprom(address+i, *array);
array++; i++; }
} // Start of main ..
fprintf(COM1, "\r\n Initialising Setup Structure Defaults : ");
trx.Kp = 10;
trx.Ki = 20;
trx.Kd = 35;
trx.is_setup = 0x62;
strncpy(trx.ident, CHANNEL, sizeof(CHANNEL));
void load_setup_from_nvm()
fprintf(COM1, "\r\nLoading setup from NVM : ");
read_eeprom_string(&buffer[0], 0, sizeof(trx));
memcpy(&trx, &buffer[0], sizeof(trx));
fprintf(COM1, "\r\nChecking - setup from NVM : %f %f %f", trx.Kp, trx.Ki, trx.Kd);
fprintf(COM1, "\r\nChecking setup value : %02x", trx.is_setup);
fprintf(COM1, "\r\nPress a key to continue");
getch();
void save_setup_to_nvm()
fprintf(COM1, "\r\n Saving Setup to NVM : ");
memcpy(&buffer[0], &trx, sizeof(trx)); // Copy initialised stucture
write_eeprom_string(&buffer[0], 0, sizeof(trx));
trx.Kp=0;
trx.Ki=0;
trx.Kd=0;
trx.is_setup = 0;
Posted: Wed Jan 20, 2010 3:24 pm |
Write a small test program to prove that you can write a byte to eeprom
and then read it after a reset or power-up. Here's an example:
http://www.ccsinfo.com/forum/viewtopic.php?t=22109&start=17
Note: For 18F PICs, the #rom address for eeprom is 0xF00000 (5 zeros
after the 'F'). |
ac34856
Posted: Thu Jan 21, 2010 7:29 am |
Thanks PCM,
this seems to work but started giving me trouble when porting
to the main application - possibly running out of RAM ? ..
Will plod on with it see where I get..
| Code: | //*********************************************************
// 18F4620-Setup-Write-V2.c
// Notes: This program works and appears to be correct
// Modifications: Requires Error Traps Adding.
#device *= 16;
#include <stdio.h>
#include <string.h>
#include <stdarg.h>
void dump_eeprom(int16);
char is_setup ; //
} trx, *ptrx ; //
char ch=0;
int16 counter=0;
int16 s_size;
ptrx = &trx;
fprintf(COM1, "====[ CPU Reset ]===\r\n");
fprintf(COM1, "\r\n 3. Initialise Default Setup");
fprintf(COM1, "\r\n 6. Dump EEPROM (0-100)");
fprintf(COM1, "\r\n 7. Reset CPU ");
ch=getch();
switch (ch)
continue;
continue;
continue;
continue;
// erase_nvm(sizeof(trx));
continue;
case '6' : dump_eeprom(100);
continue;
case '7' : reset_cpu();
continue;
default : break;
int16 i=0;
for (i=0; i<size; ) write_eeprom(i++, 0xff);
int8 i = 0;
*array = 0;
else { array++;
*array=0; }
i++; }
int8 i=0;
while(i < max_size)
array++; i++; }
trx.Kp = 10;
trx.Ki = 20;
trx.Kd = 35;
int16 s_eeprom;
s_eeprom = getenv("DATA_EEPROM");
fprintf(COM1, "\r\n Size of EEPROM : %Ld Bytes ", s_eeprom);
fprintf(COM1, "\r\n Setup values from NVM : %f %f %f", trx.Kp, trx.Ki, trx.Kd);
fprintf(COM1, "\r\n Setup value from NVM : %02x", trx.is_setup);
// fprintf(COM1, "\r\nPress a key to continue");
// getch();
trx.Kp=0;
trx.Ki=0;
trx.Kd=0;
trx.is_setup = 0;
void dump_eeprom(int16 size)
int16 i=0;
BYTE val;
fprintf(COM1, "\r\n Dumping EEPROM\r\n");
for (i=0; i<size; )
val=read_eeprom(i);
fprintf(COM1,"%02x ", val);
if (i % 16 == 0) fprintf(COM1,"\r\n");
++i;
