A numeric expression must appear here: error
edweir
PostPosted: Wed Jan 20, 2010 11:31 pm     Reply with quote
CCS PCM C Compiler, Version 4.057
PIC16F886
int16 t1;  //is defined up at the top of the main loop
//this is from the main loop
      if (data_flag) {
         printf("data_flag triggered\n\r");
         if (data_collected <= max_data) {
            if (packet_index < sizeof(packet0)) {
               for(k = 0; k <= (active_channels-1); k++) {
                  set_mux_chan(k);
                  t1 = get_adc_data();
                  packet0[packet_index + 2*k] = make8(t1,1);         //MSByte of data
                  packet0[packet_index + 1 + 2*k] = make8(t1,0);      //LSByte of data
                  data_collected = data_collected + 2*active_channels;
               packet_index = packet_index + active_channels*2;               // the 2 multiplier is due to 16 bit or 2 bytes of data
            if (packet_index + active_channels*2 > sizeof(packet0)) {
               ptr = packet_num*packet_index;
               writep_ext_eeprom(ptr, packet0, sizeof(packet0));
               packet_num++;
               packet_index = 0;
         else end_flag = 1;
//bit banging to an external ADC
int16 get_adc_data() {
   int16 temp_val, tmp1;
   int c;
   printf("Getting Data\n\r");
   temp_val = 0b0000000000000000;
   output_high(MUX_EN);                                    // set MUX enable bit to push through mux channel
   // set conversion bit low to start data collection
   output_low(ADC_CONV);
   // cycle through four clock cycles to get rid of the first 4 zeros
   for (c = 0; c <= 3; c++) {
      output_high(ADC_SCK);
      output_low(ADC_SCK);
   //### look at breaking this out... speed up the process significantly
   // go through 16 bits of data
   for(c = 0; c <= 15; c++){
      if (input(ADC_DIN)) tmp1 = 0b0000000000000001;  // \
      else tmp1 = 0b0000000000000000;               // /
      temp_val = (temp_val|(tmp1<<(15-c)));         // instruction time decreases with more shifts
      //nine clock cycles before here
   output_high(ADC_CONV);                                    // shut down convert bit, 20 bits should have been read: 4 zeroes and 16 bits of data.
   output_low(MUX_EN);                                       // disable MUX enable
   printf("data = %lu\n\r", temp_val);
   return temp_val;
} // end get adc data
Calling the above function in the main loop with t1 = get_adc_data(); causes the " A numeric expression must appear here ". I was able to call this function before I implemented the return, so I'm sure that's the problem but I don't know how to fix it.
Thanks for the help.
Erik
Cor. 's a rough world 'innit?
Wayne_
PostPosted: Thu Jan 21, 2010 3:33 am     Reply with quote
Which line is it complaining about ?
Where is the code that calls get_adc_data ?
Is the function defined after main or before ?
Where is the prototype ?
I suspect you modified the function header to add a return value but did not change the function prototype!
PostPosted: Thu Jan 21, 2010 7:57 am     Reply with quote
You're absolutely correct. I had, in fact, changed the header to include the returned int16... but at the same time I removed a passed variable to the function which I didn't change the function prototype to reflect! Classic too-tired too-late...
Thanks!
