18F4550 and SHT75
kizuc
18F4550 and SHT75
PostPosted: Mon Jan 18, 2010 9:52 am     Reply with quote
I need the connection of the pins of PIC 18F4550 and SHT75 sensor. I am using Nokia 3310 LCD with the connection below:
#define SCK     PIN_D7   // Connections between PIC and LCD.
#define SDI     PIN_D6
#define D_C     PIN_D5
#define _SCE    PIN_D4
#define _RES    PIN_D3
The datasheet of pin 1 is SCK, pin 2 is VDD, pin 3 is GND and pin 4 is DATA.
Kindly help me out.
Thanks in advance.
bkamen
PostPosted: Mon Jan 18, 2010 12:45 pm     Reply with quote
Check this datasheet:
http://www.sensirion.com/en/pdf/product_information/Datasheet-humidity-sensor-SHT7x.pdf
Page 4 has a typical Micrcontroller usage schematic.
Cheers,
-Ben
p.s. Whenever in doubt, check the datasheet out(!).
