ENC28J60 reg set HELP
lejm
PostPosted: Sun Jan 17, 2010 8:08 am     Reply with quote
I'm trying to setup 'led config reg' to make one led blink fast and the other one blink slow.
My code look like this:
#define CS  PIN_D2
output_high(CS);
 setup_adc_ports(AN0 |VREF_VREF);
 setup_adc(ADC_CLOCK_DIV_8);
set_adc_channel(0);
   setup_psp(PSP_DISABLED);
   setup_spi(SPI_MASTER|SPI_L_TO_H|SPI_CLK_DIV_4);
   setup_wdt(WDT_OFF);
   setup_timer_0(RTCC_INTERNAL);
   setup_timer_1(T1_DISABLED);
setup_spi(SPI_MASTER | SPI_H_TO_L | SPI_CLK_DIV_16);
output_low(CS);
spi_write(0x5F06); //  SELECT '2' REG BANK
//output_high(CS);
//delay_ms(10);
//output_low(CS);
spi_write(0x5410); // WRITE 'x10' to 14 REG of 2 BANK to point to the 'led config reg'
//output_high(CS);
//delay_ms(10);
//output_low(CS);
spi_write(0x563B); // WRITE UPPER BIT VALUE
//output_high(CS);
//delay_ms(10);
//output_low(CS);
spi_write(0x57A0); // WRITE LOWER BIT VALUE
output_high(CS);
//spi_write(0x214DD0); //write 0x80 to SPI device
Code has no effect ;/
Leds are off all the time.
What am I doing wrong?
PostPosted: Sun Jan 17, 2010 3:02 pm     Reply with quote
What size value does spi_write take.
What size value are you giving it.....
lam
PostPosted: Sun Jan 17, 2010 4:04 pm     Reply with quote
I have no idea.
As is in the Datasheet of ENC.
Im writing for example spi_write(0x5F06);
to point to the 2'nd bank by writing to the ECON1 register.
spi_write(0x5F06); is equal of
bin (010 11111 00000110)
010 mean that we will Write Control Register
11111 is pointer to the register (in this case ECON1)
00000110 is new value to be written into register.
So im sending 2 bytes.
Is there anyone who work with ENC and is able to give me clear answer ? [;
PostPosted: Sun Jan 17, 2010 4:42 pm     Reply with quote
Download the CCS manual and look at the allowable size of the
parameter for the spi_write() function. Hint: it's not 16-bit.
http://www.ccsinfo.com/downloads/ccs_c_manual.pdf
lejm
PostPosted: Mon Jan 18, 2010 9:19 am     Reply with quote
so how to transmit : 0x5F06
spi_write(0x5F);
spi_write(0x06); ?
