Will this work?
Core2
Will this work?
PostPosted: Sat Jan 16, 2010 12:13 pm     Reply with quote
Hello everyone,
My 'C' is rusty. I need to set a signal and wait for a response. Here is my function:
void getSonar (void)
   output_high(TRIGGER);  //Initiate the Sonar sequence
   setup_timer_1(T1_INTERNAL|T1_DIV_BY_2); //Start counting, 0.4uS tick time
   while (!echo_rcvd){}  //Wait for echo
   printf("Range = %lu inches\n\r",range/185);  //Print range
   //Need to check if 185 is the right number; not so sure.
   output_low(TRIGGER);
Its the While statement I'm not sure about. Do I need the braces? I have the ECHO line tied to RB5 as in IOC. The ISR will SET 'echo_rcvd' to TRUE'
I'm running this on a PIC16F882, compiler 4.093.
Thanks,
Duane
bungee-
PostPosted: Sat Jan 16, 2010 3:03 pm     Reply with quote
You should do the setup timer routine at uC init not in this function. In the function you just call set_timer1(0);
while (condition) {} <--- Is OK, it just waits in that spot until your condition is met.
Core2
PostPosted: Sat Jan 16, 2010 5:21 pm     Reply with quote
Thanks for the info. Will move the Timer setup.
What command actually makes the timer start?
Duane
bungee-
PostPosted: Sat Jan 16, 2010 5:52 pm     Reply with quote
Duane
Timer will be running all the time, you'll just set the timer1 to 0 with that command. So you'll be able to get time measurement.
Core2
PostPosted: Sat Jan 16, 2010 6:01 pm     Reply with quote
Gotcha. Thanks!
