Pic24: Problem with oscillator output
nicotec
PostPosted: Sat Jan 16, 2010 4:45 pm     Reply with quote
Hi, on my pic24fj16ga002 I need to disable oscillator output on pin 10 (RA3) to be used as input.
I'm using pic with internal fast oscillator and ccs compiler 4.093:
#BYTE CW2=0x002BFC
#BIT OSCIOFCN = CW2.5
OSCIOFCN=0;
The above code doesn't work, can anyone help me?
Thanks and regards
nicotec
Help!
PostPosted: Sun Jan 17, 2010 2:46 am     Reply with quote
Please can anyone help me?
PostPosted: Sun Jan 17, 2010 3:37 am     Reply with quote
OSCIOFCN is a #fuses bit. See PCD valid fuses overview.
nicotec
not fuse
PostPosted: Sun Jan 17, 2010 5:34 am     Reply with quote
Thanks but it doesn't appear in the list of valid fuses; any suggestion?
PostPosted: Sun Jan 17, 2010 7:31 am     Reply with quote
From V4.093 24FJ16GA002.h header file:
//////// Fuses: SOSC,LPRC,FRC_PS,CKSFSM,NOCKSFSM,OSCIO,NOOSCIO,NOPR,HS,XT,EC
Can you guess the fuse name? The valid fuses list has also an explicite explanation for each fuse!
nicotec
Not so clear
PostPosted: Sun Jan 17, 2010 4:01 pm     Reply with quote
I checked the fuses, but there are no clear reference to the byte/bit needed to put zero to use port A3 as input/output, I have also checked with oscilloscope and clock is still present; if you have suggestion on which fuse needed to try because is not so clear in description and may be that it is not available.
PostPosted: Mon Jan 18, 2010 12:46 am     Reply with quote
Generally, if the CCS C documentation appears unclear to you, refer to the Microchip datasheet. If the the
latter is insufficient, complain at Microchip!
In this case, the "Fuse Review" (Valid fuses menu) contains this info:
3.05 NOOSCIO OSC2 is clock output
3.05 OSCIO OSC2 is general purpose output
Isn't it fully self-explanatory?
If the respective #fuses entry don't work as expected, check the actual generated config word against
the Microchip datasheet. I didn't check it, because I don't use this setting.
1980best
PostPosted: Sat Aug 27, 2011 3:22 am     Reply with quote
bit 5 OSCIOFCN: OSCO Pin Configuration bit
If POSCMD1:POSCMD0 = 11 or 00:
1 = OSCO/CLKO/RA3 functions as CLKO (FOSC/2)
0 = OSCO/CLKO/RA3 functions as port I/O (RA3)
If POSCMD1:POSCMD0 = 10 or 01:
OSCIOFCN has no effect on OSCO/CLKO/RA3.
the problem continues.
help help help .....
PostPosted: Sat Aug 27, 2011 4:03 am     Reply with quote
You do understand that the fuse is called OSCIO (For I/O on the oscillator pins), as FvM, has already pointed out. Haven't got 4.093, but on 4.099, setting this, happily allows I/O on the pin..
If your compiler predates this fuse being implemented, you have three choices:
1) Update the compiler.
2) Add a #ROM statement with the bit pattern needed for the fuses.
3) Change the fuse in your programmer, before writing the chip.
1980best
PostPosted: Mon Sep 05, 2011 6:04 am     Reply with quote
#include <24FJ16GA004.h>
#FUSES ICS3                     //ICD communication channel 3
#FUSES NOIOL1WAY                //Allows multiple reconfigurations of peripheral pins
#FUSES NOWINDIS                 //Watch Dog Timer in Window mode
#FUSES WPRES128                 //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS1                  //Watch Dog Timer PostScalar 1:1
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#FUSES FRC                      //Internal Fast RC Oscillator
#FUSES NOSKSFSM                 //Clock Switching Mode is disabled
#FUSES OSCIO                  //OSC2 is general purpose output
#FUSES NOPR                     //Pimary oscillaotr disabled
#FUSES I2C1SELD
#use delay(clock=8000000)
   setup_oscillator(OSC_INTERNAL);
   output_low(PIN_A2);
   output_low(PIN_A3);
   output_low(PIN_C3);
   output_low(PIN_C9);
  while(true)
      output_toggle(PIN_A2);
      DELAY_mS(1);
      output_toggle(PIN_A3);
      DELAY_mS(1);
      output_toggle(PIN_C3);
      DELAY_mS(1);
      output_toggle(PIN_C9);
      DELAY_mS(1);
///////////////// This problem is solved ///////////////
razor1983m
PostPosted: Tue Sep 06, 2011 4:39 am     Reply with quote
#FUSES FRC_PLL //Internal Fast RC Oscillator
#FUSES I2C1SELD
output_low(PIN_A2);
output_low(PIN_A3);
output_low(PIN_C3);
output_low(PIN_C9);
while(true)
DELAY_mS(1);
DELAY_mS(1);
DELAY_mS(1);
DELAY_mS(1);
This ok working.... Laughing Laughing
