XOR byte operator
guest
XOR byte operator
PostPosted: Fri Oct 08, 2004 9:00 am     Reply with quote
Does anyone know what the byte operator is for a XOR operation?
Regards,
Darren
Re: XOR byte operator
PostPosted: Fri Oct 08, 2004 9:19 am     Reply with quote
Regards,
Darren
guest
PostPosted: Fri Oct 08, 2004 9:33 am     Reply with quote
Isn't that a bit-wise operator. I want to XOR two bytes together as a basic checksum.
i.e.
XOR   10011001
      11000010
Any other thoughts?
Darren.
PostPosted: Fri Oct 08, 2004 10:32 am     Reply with quote
i.e.
XOR   10011001
      11000010
Any other thoughts?
Darren.
That is what the operator does. an XOR of each bit in the byte with the corresponding bit in the other byte. It is 'bitwise', because it does this, rather than treating the whole byte as a 'logical' entity.
jamesjl
View user's profile Send private message Visit poster's website Yahoo Messenger MSN Messenger
PostPosted: Fri Oct 08, 2004 10:49 am     Reply with quote
Great,
Thanks for the help.
Squintz
PostPosted: Fri Jan 15, 2010 1:43 pm     Reply with quote
Sorry to bring up such an old thread. Newbie Here!
Is it valid to XOR two inputs to determine an output? Below is what I am trying to do. Basically I want to compare a Switch to an LED and if they are different I want to toggle an output. For some reason I never see the output go High. It constantly stays low. What am I doing wrong?
#include <12F675.h>
#fuses INTRC_IO     //Inernal RC Oscillator
#fuses NOWDT        //No Watchdog Timer
#fuses NOBROWNOUT   //No Brownout Detection
#fuses NOMCLR       //No Master Clear Reset. Used for I/O Instead
#use delay(clock=31000) //
      // if the Switch and the LED are opposite then toggle the power
      if(input(PIN_A3)^input(PIN_A2))       // XOR Switch to LED
         //Turn the unit on
          output_low(PIN_A5);                 // Simulate power button press
            delay_ms(500);                  // Wait with button pressed...
            output_float(PIN_A5);            // Simulate power button release
      }else{
      delay_ms(200);                         // Wait before checking again.
Rohit de Sa
PostPosted: Fri Jan 15, 2010 2:37 pm     Reply with quote
^ is a bitwise operator, not a logical operator.
You could always try:
int1 a=0;
int1 b=0;
int1 c=0;
a=input(pin_a3);
b=input(pin_a2);
c=((!a)&&b)||(a&&(!b));
if(c)
Rohit
Squintz
PostPosted: Fri Jan 15, 2010 3:19 pm     Reply with quote
I actually got it to work pretty much exactly how it is but I changed output_float to output_high. It was executing the code I just was not seeing it on my oscope because float essentially disconnect the output pin. I thought float was the same as high but I guess I was wrong.
Thanks for the alternative solution.
PostPosted: Fri Jan 15, 2010 3:43 pm     Reply with quote
Applying ^ to int1 respectively bit variables achieves a "logical" XOR. In so far, bitwise operator function
includes the logical. Applying a logical operator to variables larger than one bit performs an implicite (var !=0)
before the logical operation.
There have been however issues, at least with CCS V3, where bits in structures have been erroneously
bitwise processed in logical operations.
In the present case, using ^saves a few machine instructions, although the generated code is very similar to
the suggested more long-winded construction.
