vardhan Guest
| Reading eeprom to a pointer with separator |
Posted: Fri Jan 15, 2010 12:24 am |
Hi friends,
I stored a few values to the eeprom, now I need to retrieve them with a separator (,) and then move into buffer or pointer. Please any idea or sample code.
Retrieved data
ex:- 1248,5681234567,156,20,89564,12357,247,..... |
Posted: Fri Jan 15, 2010 1:39 pm |
Is this always ASCII numeric data ? Is there any text data ?
What do you want to do with the data ? Do you simply want to
parse it out into separate arrays, storing the ASCII data ?
Do you want to make it into ASCII strings ?
Or do you want to convert the data into binary integers, such as 'int32' ?
Does the data in the eeprom have the comma separators in it ?
Or did you add those later ?
Are there any separators in the eeprom other than a comma ?
Does it contain '$' or CR, LF, etc. ?
Does the data always consist of positive integers ?
Your example shows 7 values. Is it always 7 values ?
If not, what is the maximum number of values that may be in the eeprom ?
Does each field always have the same maximum size ?
Your data shows some 8bit, some 16bit, and some 32 bit.
Are the fields always in the same order, with the same maximum size ?
What PIC are you using ?
-- It probably would be a lot easier if you would say where this data
comes from and what you want to do with it. |
vardhan Guest
Posted: Fri Jan 15, 2010 10:44 pm |
Hi PCM,
The data always consists fixed size, values of int8, int16, int32 and float, no text data and always holds positive integer.
I just want to parse the retrieved data with a separator (,) and send it thru serial port from PIC16f877A to other PIC.
The eeprom will not have any separator. After retrieving I have to put a separator.
Only separator (,) is allowed. |
Posted: Sat Jan 16, 2010 3:05 am |
| How about using printf()? |
vardhan Guest
Posted: Sun Jan 17, 2010 11:12 pm |
hi,
its using fprintf... |
Posted: Mon Jan 18, 2010 1:14 am |
| Quote: | | its using fprintf... |
So what you've actually been asking for? |
