KEYPAD + LCD
Goto page 1, 2  Next
thinkpositivex
KEYPAD + LCD
PostPosted: Tue Dec 29, 2009 6:15 pm     Reply with quote
I'm doing a project to measure the condition of the 12v battery and display at LCD using LCD VOLTMETER application. This part already done. After this part I want to implement a keypad part that capable the user enter the value of the rated voltage battery and display the voltage at LCD also.
My question is what kind of main command that I should used to interrupt the part of LCD voltmeter. I want to used the keypad 4x4 for this project. Can you all help me...
Rohit de Sa
PostPosted: Wed Dec 30, 2009 11:02 pm     Reply with quote
I don't know what PIC you're using, and how many pins you have available, so here are two keypad drivers you can use. One is kbd.c, found in the CCS drivers directory, and the other is flex_kbd.c, which can be found here http://www.ccsinfo.com/forum/viewtopic.php?t=28022&start=14
In case you're looking for interrupt driven keys, use this link (also by PCM Programmer) to modify the driver http://www.ccsinfo.com/forum/viewtopic.php?t=39585&start=1.
Rohit
warriorfenix
PostPosted: Thu Dec 31, 2009 11:31 am     Reply with quote
I hope this code help you with your doubts, not exactly what you want but you will serve
#include <16f873a.h>
#include <lcd2.c>
#fuses XT, NOWDT
const int escala = 255;
const float v_max = 5.0;
int valor;
float voltaje;
void calcula_voltaje (int val, float &voltaje)     //Funcion conversión pzra conseguir voltaje
voltaje=(val*v_max)/escala;
void conversor()
   setup_adc(adc_clock_div_32);                    //Enciende conversor
   setup_adc_ports(ra0_ra1_ra3_analog);            //Selecciona los puertos
   set_adc_channel(3);                             //Selecciona canal
   valor=read_adc();                               //Conversión AD almacenada en valor
   calcula_voltaje(valor,voltaje);                 //Llamamos a la funcion de conversión
   setup_adc(adc_off);                             //Apaga el conversor
   setup_adc_ports(no_analogs);                    //Configura terminales como digitales
   main()                                          //Programa principal
   while(1)                                        //Bucle
    conversor();                                   //Llamamos al conversor para realizar la medida y lo apagamos
    lcd_init();                                    //Inicializamos la lcd y representamos el valor
    lcd_putc("voltios = ");
    lcd_gotoxy(16,1);
    lcd_putc("V");
    lcd_gotoxy(11,1);
    printf(lcd_putc,"%1.2f",voltaje);
thinkpositivex
PostPosted: Thu Jan 07, 2010 8:39 pm     Reply with quote
I'm using PIC 16f877a, and ccs compiler 4.084 version.
For your information I already run 1 example program from this forum that consist of keypad and driver. My problem is why my lcd is active low after execute. I used the driver keypad and lcd from program files and loaded to this program.
#include <16f877a.h>
#fuses XT,NOWDT,PUT,NOBROWNOUT,NOLVP
#include <LCD.C>
#include <KBD.C>
   char c;
   lcd_init();
   kbd_init();
      c=kbd_getc();
        if(c!=0)
          if(c=='*')
            lcd_putc('\f');
            lcd_putc(c);
The lcd connection:
RD0 - E
RD1 - R/S
RD2 - R/W
RD3 - no connection
RD4-D4
RD5-D5
RD6-D6
RD7-D7
For keypad connection I refer from keypad driver using port B, added with 10K resistor at row.
#define COL0 (1 << 5)
#define COL1 (1 << 6)
#define COL2 (1 << 7)
#define ROW0 (1 << 1)
#define ROW1 (1 << 2)
#define ROW2 (1 << 3)
#define ROW3 (1 << 4)
PostPosted: Fri Jan 08, 2010 1:55 pm     Reply with quote
In a previous thread, you said you're using Proteus. Post your Proteus
schematic on a free image posting website. Then post a link to it, so we
can look at it.
thinkpositivex23
circuit picture
PostPosted: Wed Jan 13, 2010 8:46 am     Reply with quote
John P
PostPosted: Wed Jan 13, 2010 10:10 am     Reply with quote
I compared that circuit diagram to the LCD wiring in one of my projects, and I had pin 1 of the LCD connected to GND, where you have it going to VCC. Are you sure this is right? Also, the 4-bit mode of operation of the LCD is fine and it's what I used, but you should connect the unused input pins to GND. And finally, I had an unpleasant surprise when I changed to a different brand of LCD. The display was invisible when the LCD pin 3 (contrast setting) was grounded. I had to wire up a voltage divider between GND and VCC before I could see anything. So beware.
PostPosted: Wed Jan 13, 2010 2:51 pm     Reply with quote
LCD's have internal pullups on the unused data bus pins (DB0-DB3), so
they're not floating. You don't have to connect them to ground.
Connect the Vdd pin on the LCD to power, and the Vss pin to ground.
Then it will probably work.
thinkpositivex
PostPosted: Wed Jan 13, 2010 9:41 pm     Reply with quote
I already try what you are suggest...but it could not operated also.
Can you help me? I think it caused by the coding. Maybe the driver for the LCD or KEYPAD must be altered before execute this circuit.
PostPosted: Wed Jan 13, 2010 9:52 pm     Reply with quote
You're using the CCS keypad driver, not the flex keypad driver.
In that case, you need to tell it to use Port B. The #define statement
must be above the #include statement for the KBD.C file.
#define use_portb_kbd TRUE
#include <LCD.C>
#include <KBD.C>
char c;
thinkpositivex
thanks...PCM programmer
PostPosted: Wed Jan 13, 2010 10:50 pm     Reply with quote
Thank you very much. I have 1 question, if I want to change the keypad to the 4x4 keypad, can you teach me how to alter the CCS keypad driver ?
PostPosted: Wed Jan 13, 2010 11:08 pm     Reply with quote
There is a different 4x4 keypad driver here:
thinkpositivex
keypad
PostPosted: Thu Feb 04, 2010 9:09 am     Reply with quote
I already learn the command for the keypad...
but I want to know the command which, the user capable to enter 2.54 v using keypad and display to LCD.
PostPosted: Thu Feb 04, 2010 2:32 pm     Reply with quote
See this thread and the link in it, for instructions:
http://www.ccsinfo.com/forum/viewtopic.php?t=38900
thinkpositivex
FLOATING KEYPAD
PostPosted: Thu Feb 04, 2010 9:04 pm     Reply with quote
I'm new to this forum but I am willing to learn. Rolling Eyes.
If user enter on the keypad:
12.50 ( 1 2 dot 5 0 )
- How to format entered number so that it's 12.50 and not 1 2 . 5 0 or something in this matter ?
I already search the link, and I do not understand the answer of this question.
Can you explain to me.....how can we determine either the keypad is floating keypad or normal keypad?
Goto page 1, 2  Next
Page 1 of 2
