interfacing PIR sensor directly with PIC
tesla80
PostPosted: Tue Jan 12, 2010 7:42 pm     Reply with quote
Hi All,
How does it works?
Some people use big schemes with opamps to detect movement with PIR sensors, but here there is no any opamp..
Can we do this with PIC?
mcdnkfc
PostPosted: Tue Jan 12, 2010 10:45 pm     Reply with quote
I never use PIR sensor before.
But from the schematic, the C4 (1UF) can be use to block dc voltage, and the pin P07 of CY8C27 is an analog pin.
So, I guess this PIR sensor is giving you the analog signal depends on the movement it senses.
PostPosted: Wed Jan 13, 2010 1:00 am     Reply with quote
Apparently you're not motivated to check the features of the involved PSoC respectively processor chips
yourself? It's always instructive, I think. Actually both have considerable internal signal gain. When your PIC
doesn't provide it, you better use external amplifiers.
tesla80
PostPosted: Wed Jan 13, 2010 5:50 am     Reply with quote
Yes you are right. MSP430 uses 4x internal gain.
But the opamp circuits for PIR don't contain only amplifier... Differentiator->amplifier->window comparator...
There is no PIC with internal gain, right?
PostPosted: Wed Jan 13, 2010 6:56 am     Reply with quote
The said MSP has a differential 32 mV full range 16-bit ADC, if I understand right. That means, the
detection sensitivity can be up to several 1000 times higher than with a PIC and 10 bit ADC. The circuit
is also involving a highpass, more processing can be done by software.
I think, there's no PIC with internal gain. General, you have to determine the required analog resolution for
your application. I've used PIR sensors for measurement applications, but not designed motion detectors,
so I can't suggest a value, but I assume sub mV. Thus an amplifier would be needed.
