start and stop the process
Goto page 1, 2  Next
hayee
PostPosted: Mon Jan 04, 2010 6:51 am     Reply with quote
hi,
i want to start a process at defined time and then stop the process at defined time.I have connected a gps system which gives me exact time.
whenever gps time equal to my defined start time the process begins and whenever gps time is equal to stop time the process stops.Below is the code
if((hour==hour1)&(min==min1)&(sec==sec1))//start time
   start=1;//my desired function starts.
  if((hour==hour2)&(min==min2)&(sec==sec2))//stop time
   start=0;// my function stops here.
This code is works perfect only when my system is power up before the defined start time.
What i want to do is that whenever i power up the system it compare the gps time with start time,If the gps time is >= start time the process starts and when the gps time == stop time the process stops and will remain in the stop mode untill gps time will equal to start time again.
John P
PostPosted: Mon Jan 04, 2010 7:05 am     Reply with quote
Easy one. Your conditions are joined by '&'; they should be joined by '&&'.
Also, how often are you checking this? If you don't do it at least once a second, you risk missing the correct time. And if you do check it more frequently, is it OK if the "start" condition occurs more than once?
hayee
PostPosted: Mon Jan 04, 2010 11:37 pm     Reply with quote
ya I am checking more than once in a second.
Let suppose start time is 07:30:0 and stop time is 10:10:45.
what I want to do is that when gps time is between start and stop time the process remains start and when gps time is greater than stop time the process will be stop.
2nd thing I want to add is that if I ON the system after 07:30:0, let suppose 08:00:00, then the process should follow the same procedure as I describe above.
Is there any idea regarding this.
mbradley
PostPosted: Tue Jan 05, 2010 12:03 am     Reply with quote
When I program on Linux systems, time is in seconds past the epoch, details aside, convert your time to seconds.
With this example, start will be 1 if the time is anywhere between start and stop.
timeStamp = (hour * 3600) + (min*60) + sec;
if ( (timeStamp >= startTime) && (timeStamp < stopTime) )
  start = 1;
  start = 0;
Michael Bradley
www.mculabs.com
Open Drivers and Projects
John P
PostPosted: Tue Jan 05, 2010 8:10 am     Reply with quote
I thought of suggesting something like MRBradley's approach, but I held off because there seemed to be a problem: what happens if the desired interval wraps around past midnight, i.e. starts one day and ends the next day? At least if you use an equality test you don't have that issue. The way around it would be to add a test for the date as well as the time, but that's getting more complicated.
mbradley
PostPosted: Tue Jan 05, 2010 10:37 am     Reply with quote
John P: Very good point! I didnt even think about it.
If the stop time ends on the following day, it does it a lil bit convoluted, I guess we would need more info.
Michael Bradley
www.mculabs.com
hayee
PostPosted: Tue Jan 05, 2010 11:03 pm     Reply with quote
mbradley according to your suggestion I tried it but it is not working well.
JohnP I am not getting your point.
mbradley
PostPosted: Wed Jan 06, 2010 12:13 am     Reply with quote
Roughly, I think the max is 90060, based on 24hr clock, so you will need an int32 to hold the timeStamp.
if you are using 12hr, then you need to add 43200 if the pm flag is set.
Michael Bradley
www.mculabs.com
hayee
PostPosted: Tue Jan 12, 2010 12:52 am     Reply with quote
mbradley thanks for your help but this technique is not working,
mbradley
PostPosted: Tue Jan 12, 2010 12:55 am     Reply with quote
would you be able to show me the time variables you have, and what they contain?
such as;
int8 day;
int8 month;
etc...
Also, can you give me a specific start and stop time?
Michael Bradley
www.mculabs.com
hayee
PostPosted: Tue Jan 12, 2010 2:13 am     Reply with quote
following is the part of my code
main()
   int32 start_time,stop_time;
   int32 current_time;
   unsigned int hour1=0,hour2=0,min1=0,min2=0,sec1=0,sec2=0;
   start_time=(hour1*3600)+(min1*60)+sec1;//values are stored in eeprom
   stop_time=(hour2*3600)+(min*60)+sec2;//values are stored in eeprom
   current_time=(hour*3600)+(min*60)+sec;//this time is from gps
   if((current_time>=start_time) &&(current_time<=stop_time))
    start=1;
   start=0;
   pulse_ms=0;
I want to start and stop process at the user defined time or the default start time is 7:00:00 and stop time is 17:00:00
mbradley
PostPosted: Wed Jan 13, 2010 12:44 am     Reply with quote
unless I am missing something, that looks about right.
if I get a chance I will test it out. right now, off to bed...
Michael Bradley
www.mculabs.com
hayee
PostPosted: Wed Jan 13, 2010 1:14 am     Reply with quote
Ok mbradley thanks.
Any other suggestions from other users.
PostPosted: Wed Jan 13, 2010 3:34 am     Reply with quote
Look at the mktime function.
This returns the standard 'unix' time, as an int32. The source code is with the compiler, so it is easy to modify to suit any particular RTC format that you have.
This allows mkbradley's 'original' Lnux solution to work 'as is'.
It really is the 'best' approach.
hayee
PostPosted: Wed Jan 13, 2010 5:21 am     Reply with quote
From where i get the mktime function.
Goto page 1, 2  Next
Page 1 of 2
