Problem with array when using PIC24FJ128GA010
mcdnkfc
PostPosted: Tue Jan 12, 2010 1:38 am     Reply with quote
Hi all, I'm using PIC24FJ128GA010, and compiler ver4.088.
Here is the problems:
#include <24fj128GA010.h>
#fuses HS,PR_PLL    // Crystal HS, 4xPLL
#fuses NOIESO       // No 2-speed Start Up
#fuses NOJTAG       // No JTAG
#fuses NOPROTECT    // No Memory Protection
#fuses NOWDT        // No WatchDog Timer
#fuses NODEBUG      // Debug Mode.
#use delay(clock=32M, oscillator=8M)
#use rs232(UART2, STREAM=serial_debug, baud=9600, bits=8)
/********Global Variable*************/
float data1[2]={10,20};
/*********Main Program***************/
   unsigned char a;
   a = 0;
   printf("%0.0f\r\n"data1[a]);
   a = 1;
>>It prints out:
>>0
>>0
But, if this, it is ok:
/***********Global Variable*************/
/**************Main Program**********/
   printf("%0.0f\r\n"data1[0]);
   printf("%0.0f\r\n"data1[1]);
>>and print out
>>10
>>20
I also try out this and it's work:
/***********Global Variable****************/
char data1[2]={10,20};
/**************Main Program**************/
   unsigned char a;
   a=0;
   printf("%u\r\n"data1[a]);
   a=1;
So, is there any problems with the variable 'a' when it locating the floating point array?
PostPosted: Tue Jan 12, 2010 1:52 am     Reply with quote
V4.088 has considerably more PCD bugs then recent versions. 32 bit operations are one favourite place for it.
mcdnkfc
PostPosted: Tue Jan 12, 2010 3:03 am     Reply with quote
So, is there any solution others than I change my compiler?
bcos I'm stuck here.... Crying or Very sad
Wayne_
PostPosted: Tue Jan 12, 2010 3:20 am     Reply with quote
Just a note,
there should be a comma between the format string and the data e.g.
printf("%0.0f\r\n", data1[a]);
Also try
a = 0;
float f;
f = data1[a];
   printf("%0.0f\r\n", f);
PostPosted: Tue Jan 12, 2010 3:36 am     Reply with quote
I was able to fix previous PCD bugs with 32-bit data and pointers by cutting complex expressions to more simple ones, like Wayne suggested.
mcdnkfc
PostPosted: Tue Jan 12, 2010 6:08 pm     Reply with quote
I tried but still the same problem.
I already gave up v4.088 and changed to C30.
PostPosted: Wed Jan 13, 2010 1:27 am     Reply with quote
I compiled your float example with PCD V4.087 and if works O.K.
   a=0;
