33FJ128GP804 & DAC
rlaj
33FJ128GP804 & DAC
PostPosted: Wed Aug 19, 2009 5:09 am     Reply with quote
I am using the dsPIC 33FJ128GP804 and PCD 4.089. I have some problems working on the DAC.
A summary of my code is:
#word DAC1CON  = 0x03F0
#word DAC1STAT = 0x03F2
#word DAC1DFLT = 0x03F4
#word DAC1RDAT = 0x03F6
#word DAC1LDAT = 0x03F8
#define DAC_ON 0x00008000
#define DAC_OFF  0
#define DAC_RIGHT_ON   0x00808000
#define DAC_LEFT_ON    0x80008000
#define DAC_LEFT_MIDPOINT  0xA0008000
#define DAC_RIGHT_MIDPOINT  0x00A08000
#define DAC_SIGNED   0x00000100
#define DAC_SLEEP_ON 0x00001000
#define DAC_IDLE_OFF 0x00002000
#define DAC_CLOCK_DIV_BY_1 0x00000000
void DACSetup(int32 regist, int16 def=0){
   output_drive(PIN_B12);         //outputs
   output_drive(PIN_B13);
   output_drive(PIN_B14);
   output_drive(PIN_B15);
   output_drive(PIN_C0);         //DAC1RM
   DAC1DFLT = def;            //default value set to Midpoint
   DAC1CON = (int16)(regist);
   DAC1STAT = (int16)(regist >> 16);
void main(){
   int16 i=0x8000;
   DACSetup(DAC_RIGHT_ON | DAC_RIGHT_MIDPOINT | DAC_SIGNED | DAC_SLEEP_ON | DAC_CLOCK_DIV_BY_6 | DAC_ON, 0x8000);
   while(TRUE){
      DAC1RDAT = ++i;
After configurating DAC1CON=0x9105 and DAC1STAT=0x01A2 (DAC enabled, it continues in idle mode, right channel & midpoint enable). After that, the output has a fixed voltage around 1.82V. When I write in DAC1RDAT the voltage doesn't change, in debug mode the DAC1RDAT register doesn't vary.
Another question, how I can use the interrupts of this DAC?
Thanks.
Regards.
treanla
Same problem on dspic33fj64gp802
PostPosted: Mon Dec 28, 2009 8:49 am     Reply with quote
There must be something we are missing.
Also the definition file (headerfile ) for 802 seems to lack any support for DAC interrupts.
bharath
ds PIC 33fj128GP802
PostPosted: Sun Jan 10, 2010 9:26 am     Reply with quote
hi im also getting same problem with this chip
is u r able to fine soultion
plz let me know
very urgent...........
treanla
4.104 with DAinterrupts works
PostPosted: Mon Jan 11, 2010 2:18 am     Reply with quote
With 4.104 we now have DA interrupts defined.
Then you can easily adopt the Microchip application sample found on their site DAC_SINEWAVE.ZIP. Its available as download when you go into the datasheet section of the 802 chip.
Just change the ISR defines to #INT_xxx for DAC and rename Microchips xxxbits.yyy to CCS style MCU_xxx.yyy and it will compile as is.
treanla
clarification
PostPosted: Mon Jan 11, 2010 2:19 am     Reply with quote
Forgot to mention that the CCS DAC routines will not work here !
You must program the registers yourself and in the Microchip sample.
buchtsucht
Timing
PostPosted: Thu Jun 03, 2010 12:53 am     Reply with quote
I had exactly the same problem. After trying several settings everything is O.K.
The "intelligent" circuit inside the PIC, that smooths DAC ripple, seems to makes problems (shut down the DAC?), if you donĀ“t feed the DAC at the right time. Correct settings of the aux. oscillator are important.
This should work (clock source = 10 MHz external clock):
#include <33FJ64GP802.h>
#FUSES NoWDT                       // Watch Dog Timer
#FUSES WPOSTS1
#FUSES NOPROTECT
#FUSES CKSFSM                     //Clock Switching is enbled
#FUSES PR_PLL                   //Primary Oscillator with PLL
#word    DAC1STAT =0x03F2         // DAC left/rigth enable
 #bit        ROEN = DAC1STAT.7       // Right Channel DAC Output Enabled //
 #bit      RITYPE = DAC1STAT.2      // Right Channel Interrupt if FIFO is not Full //
#word     DAC1CON =0x03F0         // DAC settings
 #bit       AMPON = DAC1CON.12      // Amplifier Disabled During Sleep and Idle Modes //
 #bit        FORM = DAC1CON.8       // Data Format is Unsigned //
 #bit    DACFDIV6 = DAC1CON.6       // Divide Clock
 #bit    DACFDIV5 = DAC1CON.5       // Divide Clock
 #bit    DACFDIV4 = DAC1CON.4       // Divide Clock
 #bit    DACFDIV3 = DAC1CON.3       // Divide Clock
 #bit    DACFDIV2 = DAC1CON.2       // Divide Clock
 #bit    DACFDIV1 = DAC1CON.1       // Divide Clock
 #bit    DACFDIV0 = DAC1CON.0       // Divide Clock
#word    DAC1DFLT =0x03F4         // DACR Default Wert
#word    DAC1LDAT =0x03F6         // DAC Value LEFT
#word    DAC1RDAT =0x03F8         // DAC Value RIGHT
#word     ACLKCON =0x074A         // DAC Auxiliary Oscillator settings
#word        IFS4 =0x008C         // DAC Interrupt status register
 #bit     DAC1RIF = IFS4.15         // Clear Right Channel Interrupt Flag //
 #bit     DAC1RIE = IFS4.14       // Right Channel Interrupt Enabled //
#word CLKDIV=0x0744
#word PLLFBD=0x0746
#use FAST_IO (B)
#use delay(clock=41890000)
int a,b;      long aa,bb,cc;
void Main(){
SETUP_WDT(WDT_OFF);
   CLKDIV=0b0000000000011011;PLLFBD=0xF1;          //41 Mhz PLL
       //54L21098R6543210
ACLKCON =0b0000000010000000;   // 14[0]=Fvco / [1]=AUX/10Mhz // 10..8 divider 000=256 // 7 [1]=10Mhz
DAC1STAT=0b1000000010000000;
DAC1CON =0b1001000000000011;
while(1){for(cc=0;cc<=65535;++cc) {cc=cc+256;while((bit_test(DAC1STAT,1))==1);dac1ldat=cc;}
