How can I set PIC24FJ256GB106 Fuse
sindyme
PostPosted: Sun Jan 10, 2010 9:32 pm     Reply with quote
My Uart work have garbled.
My external crystal is 22.1184Mhz.
There is my FJ256GB106 .h file set.
Could everyone check it, plz. ~ Thanks. Very Happy Smile
#FUSES NOJTAG                   //JTAG disabled
#FUSES NOPROTECT             //Code not protected from reading
#FUSES NODEBUG                //No Debug mode for ICD
#FUSES ICS0                       //ICD communication channel 0
#FUSES WINDIS                   //Watch Dog Timer in non-Window mode
#FUSES WPRES128               //Watch Dog Timer PreScalar 1:128
#FUSES WPOSTS16              //Watch Dog Timer PostScalar 1:32768
#FUSES IESO                       //Internal External Switch Over mode
                                             enabled
//#FUSES FRC_PS                   //Fast RC Oscillator with Post Scaler
#FUSES NOCKSFSM                 //Clock Switching is disabled, fail Safe
                                                clock monitor is disabled
#FUSES NOOSCIO                  //OSC2 is general purpose output
#FUSES HS                            //High speed Osc (> 4mhz for PCM/PCH)
                                               (>10mhz for PCD)
#FUSES IOL1WAY                  //Allows only one reconfiguration of
                                               peripheral pins
#FUSES WPEND_LOW
#FUSES NOWPCFG
#FUSES NOWPDIS
#FUSES WPFP0
//#FUSES PLL12                    //Divide By 12(48MHz oscillator input)
#FUSES RESERVED                 //Used to set the reserved FUSE bits
#use delay(clock=22118400)
#use rs232(UART1,baud=115200,XMIT=PIN_G6,RCV=PIN_G7,parity=N,bits=8,stream=coma)
#users232(UART1A,baud=115200,XMIT=PIN_D0,RCV=PIN_D11,parity=N,bits=8,stream=comb)
Very Happy Smile
FvM
PostPosted: Mon Jan 11, 2010 12:04 am     Reply with quote
I don't hear a problem reported or a clear question. To understand, if your configuration can be understood by PCD, tell the compiler version.
sindyme
PostPosted: Mon Jan 11, 2010 12:47 am     Reply with quote
My CCS Ver. is 4.084
Now ~ My uart works not normally.
It produces garbled .
I want to printf " UART TEST " , but it will sent wrong code to me !!
My crystal is 22.1184 Mhz ~
FvM
PostPosted: Mon Jan 11, 2010 1:27 am     Reply with quote
You're not selecting the external crystal as clock source, internal RC is the default.
#FUSES PR
PostPosted: Mon Jan 11, 2010 2:28 am     Reply with quote
#FUSES PR
Thank you ~
I solve Question Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy
H A P P Y ~
