how to write the power equation
farizah
PostPosted: Sun Jan 10, 2010 4:01 am     Reply with quote
I have another question, how to write mathematical equation of x power of y, in ccs compiler.
For example:
((A divide B)^C )
PostPosted: Sun Jan 10, 2010 5:37 am     Reply with quote
The same as in any standard C.....
pow
farizah
PostPosted: Sat Jan 16, 2010 11:59 pm     Reply with quote
Thanks Ttelmah for helping me.
But is there another solution if I don't want to use the pow() method ? Because it is little bit slower.
PostPosted: Sun Jan 17, 2010 3:58 am     Reply with quote
It is going to depend on a lot of things.
What the likely 'scale' of the numbers are, whether you are only using integers, etc. etc.
It is often quicker to simply perform multiplication.
Pow, is slow, becaue it is 'generic', and does the power, using log, and exp. Together these take the time of about twenty+ multiplications.
So if (for instance), you are only usng int32, and want a cube, it is much faster to just code this as:
#define cube(x) (x*x*x)
Even if you want more flexibility in input number, so long as the likely powers are small, and are integer, a solution like:
int32 ipow(int32 x,int8 y) {
   int32 temp;
   if (y==0) return 0;
   if (y==1) return 1;
   temp=x;
   y--;
   do {
      temp*=x;
   } while (y--);
   return temp;
Will be far faster than pow....
kender
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger
PostPosted: Tue Aug 31, 2010 10:54 pm     Reply with quote
   int32 temp;
   if (y==0) return 0;
   if (y==1) return 1;    // return x;
   temp=x;
   y--;
   do {
      temp*=x;
   } while (y--);
   return temp;
There may be a typo. x^1 = x
Read the label, before opening a can of worms.
PostPosted: Tue Aug 31, 2010 11:36 pm     Reply with quote
y=0 is handled wrong as well. Should be correct this way
signed int32 ipow(signed int32 x,unsigned int8 y) {
   signed int32 temp = 1;
   while (y--)  temp*=x;
   return temp;
