pic16f strange problem with code please help..
jennifer
PostPosted: Thu Jan 07, 2010 5:49 am     Reply with quote
hi
i need to make this code work (i want my job ! Smile )
i wrote the next program using pic16f690 and pickit2, and problems are
1. the condition on pin c6 and c7 is to work in low but even that they have a pull-up resistor they some how considered as low and operate their FOR loop ? why ?
2. why are pins a0 a1 and a5 are allways on low when they should be on high ? why i allways having problem with port A to be output??
Thanks for answers.
#include<16f690.h>
#fuses HS,NOWDT,NOPROTECT,PUT,BROWNOUT,MCLR,NOCPD
#USE DELAY(CLOCK=31000)
#define step11 (output_high(pin_a0)) ,delay_ms(10) ;  //steps
#define step12 (output_high(pin_a1)) ,delay_ms(10) ;
#define step13 (output_high(pin_a2)) ,delay_ms(10) ;
#define step14 (output_high(pin_a5)) ,delay_ms(10) ;
#define step21 (output_high(pin_c0)) ,delay_ms(10) ;
#define step22 (output_high(pin_c1)) ,delay_ms(10) ;
#define step23 (output_high(pin_c2)) ,delay_ms(10) ;
#define step24 (output_high(pin_c3)) ,delay_ms(10) ;
#define step31 (output_high(pin_b4)) ,delay_ms(10) ;
#define step32 (output_high(pin_b4)) ,delay_ms(10) ;
#define step33 (output_high(pin_b4)) ,delay_ms(10) ;
#define step34 (output_high(pin_b4)) ,delay_ms(10) ;
int i ;
VOID MAIN()
setup_adc(ADC_OFF);
setup_spi(SPI_SS_DISABLED);
setup_comparator(NC_NC_NC_NC);//  currently not supported by the PICWizard
SETUP_CCP1(CCP_PWM);
SETUP_TIMER_2(T2_DIV_BY_16,100,1); //set to xhz
setup_oscillator(OSC_31KHZ);
WHILE(1)
// ########### condition for pwm operation
if (input(pin_a3)==0)
   set_pwm1_duty(50);
//############# conditions for steps motors.
if (input(pin_c4)==0 )
  for(i=0;i<41;i++)
      step11;
      step12;
      step13;
      step14;
   output_high(pin_a4);
   delay_ms(250);
   output_low(pin_a4);
   i=0;
if (input(pin_c6)==0 )
  for(i=0;i<41;i++)
      step21;
      step22;
      step23;
      step24;
   delay_ms(250);
   output_low(pin_a4);
   i=0;
if (input(pin_c7)==0 )
  for(i=0;i<41;i++)
      step31;
      step32;
      step33;
      step34;
   delay_ms(250);
   output_low(pin_a4);
   i=0;
}  // to while1
} // to end
PostPosted: Thu Jan 07, 2010 6:41 am     Reply with quote
Some comments:
1) Select the right clock fuse. INT_RC, or INTRC_IO. The only reason it is running at all, is either that you have a crystal attached, or that it is doing a 'fail safe' clock switch. Youu are telling it to start, using the HS oscillator....
2) Get rid of the trailing ';' on your defines. You are adding ';'s after the instructions, so these are redundant.
3) Look at what options do?. Does disabling the 'slave select', look like an instruction to turn off the SPI?. Easiest thing just to remove the line entirely. For most peripherals, the defualt is to wake up deselected...
4) Are you sure that your compiler version does turn off the comparator properly?. The comment that the wizard does not know about the disable comparator line, suggests it may not. Simply try manually turning the comparator off. PCM_programmer has posted code for doing this in the past.
jenn
thanks a lot
PostPosted: Thu Jan 07, 2010 8:46 am     Reply with quote
thanks a lot.
I did what you said but the port A is just not working, while other ports are ok.
why i always having a problems with A ?
maybe its because he is interrupt port ???
I didn't find how to disable comparators handly ..
PostPosted: Thu Jan 07, 2010 10:18 am     Reply with quote
Further comments then.
Pin A3, is the MCLR input. You have MCLR enabled in your fuses. How is this going to work.....
Pin A4, and A5, are the oscillator pins, and will _only_ become available, with INTRC_IO selected.
Add 'NOLVP' to your fuses. Pins A0, and A1, are the LVP programming pins. Should default to off, but make sure.
Basically, you _must_ read the data sheet, and ensure that your settings match what you want to do.
mkuang
PostPosted: Thu Jan 07, 2010 10:25 am     Reply with quote
Do you mean pins A4 and A5 will only become available with INTRC selected? Selecting INTRC_IO will put the internal oscillator signals on those two pins, no? In other words if you select INTRC_IO you will see a 32Khz signal on these pins when measured with a scope.
PostPosted: Thu Jan 07, 2010 3:49 pm     Reply with quote
Chapter 3.1 of the PIC16F690 datasheet:
INTRC = Internal oscillator with FOSC/4 output on A4 and I/O on A5.
INTRC_IO = Internal oscillator with I/O on both A4 and A5.
LP = external 32kHz crystal inputs on A4 and A5
XT = external 0.1 - 4MHz crystal inputs on A4 and A5
HS = external 4 - 20MHz crystal inputs on A4 and A5
EC_IO = External clock input on A5 with I/O on A4.
RC – External Resistor-Capacitor (RC) on A5 with FOSC/4 output on A4.
No, you only get clock frequency outputs with the INTRC and RC selections. The frequency of the clock output is internal_clock / 4, so for 32kHz you would have to use a 128kHz clock source and the closest available internal clock frequency is 125kHz.
JENN
THANK YOU
PostPosted: Mon Jan 11, 2010 3:00 am     Reply with quote
Thanks I have done this changes its now better, BUT
pin A0 A1 refuse to work.
I have tried to add a fuse called NOLVP and compiler says its eror ???
WHY CANT I ADD THIS FUSE ? HE SAYS "UNKNOWN KEYWORD" .
WHAT ELSE CAN CAUSE A0 A1 NOT BEING OUTPUT PORTS ?
TX.
PostPosted: Mon Jan 11, 2010 12:48 pm     Reply with quote
Look near the top of this file. It lists all available fuses for the 16F690.
If you can't set a fuse, then it's because its not available.
c:\program files\picc\devices\16f690.h
Pins A0 and A1 are used by the ICD to program or debug the 16F690.
Do you have an ICD connected to those pins ?
If that doesn't help, then post your compiler version.
