takumi
how to control by bit! |
Posted: Wed Jan 06, 2010 7:27 pm |
Hi all, I need some help to understand about controlling output ports by
bit. The code is as follows (PIC16F877A):
#define sensor1 PIN_D0
#define sensor2 PIN_D1
#define motor1 PIN_B0
#define motor2 PIN_B1
void main(){
while (1){
if(input(sensor1)==1 && input(sensor2)==1){
output_b(0b00000011);
else if(input(sensor1)==0 && input(sensor2)==1){
output_b(0b00000001);
else if(input(sensor1)==1 && input(sensor2)==0){
output_b(0b00000010);
else {
output_b(0b00000000);
The question is instead of using
Code: | output_b(0b00000011); |
can I do this:
Code: | output_b(0b000000|motor1|motor2); |
mickey231bhq
Posted: Wed Jan 06, 2010 7:35 pm |
you can use "output_high" and "output_low". |
SherpaDoug
Posted: Wed Jan 06, 2010 8:21 pm |
Try this:
#define mot1mask 0b00000001
#define mot2mask 0b00000010
Then you can turn the motors on and off with this:
output_b(mot1mask|mot2mask); //both motors on
output_b(~mot1mask&~mot2mask); //both motors off
output_b(mot1mask&~mot2mask|mot3mask&~mot4mask); //motors 1&3 on, 2&4 off |
_________________ The search for better is endless. Instead simply find very good and get the job done. |
