function problem
wannabe
function problem
PostPosted: Tue Jan 05, 2010 9:04 pm     Reply with quote
greetings...
I tried to compile a simple function prog... but it give some compile error
.... Undefined identifier.
main ()
   set_ADC_channel(0);
   delay_us(20);
   math ();
math ()
return (read_adc()*5/65500)-2.5;
wannabe
PostPosted: Tue Jan 05, 2010 9:09 pm     Reply with quote
Sorry.
The compile error is at the function math().
I tried using int16 for the function math but it give new error
............a numeric expression must appear here -1 is not 0..255.
I change to float and it give same error.
PostPosted: Tue Jan 05, 2010 9:18 pm     Reply with quote
Try this:
return ((read_adc()*5/65500)-2.5);
PostPosted: Tue Jan 05, 2010 9:21 pm     Reply with quote
You may also need to prototype the function.
math might also be a reserved word.
wanabe
PostPosted: Tue Jan 05, 2010 10:35 pm     Reply with quote
how to do this?
mbradley
PostPosted: Wed Jan 06, 2010 12:18 am     Reply with quote
just curious:
lets say the max adc is 4096, let step through:
1) 4096 * 5 = 20480
2) 20480 / 65500 = .312671756
3) .312671756 - 2.5 = -2.87328244
We end up with a negative number
I dont know if this helps or not
Michael Bradley
www.mculabs.com
Open Drivers and Projects
Wayne_
Re: function problem
PostPosted: Wed Jan 06, 2010 3:18 am     Reply with quote
wannabe wrote:
greetings...
main ()
   set_ADC_channel(0);
   delay_us(20);
   math ();
math ()
First of all the math function you have written should not return a value:-
try
float math()
Next as stated you may have to prototype the function OR define the function before it is used e.g. put the function before main.
Having to do this is standard C, in C++ and prob some C compilers you don't have to.
Next, I am a little concerned about the equation.
read_adc returns either an 8bit or 16bit int and the first part only uses 16 bit values so as mbradley shows :-
1) 4096 * 5 = 20480
The value being negative is not the problem it is step 2. With 16 bit int math :-
1) 4096 * 5 = 20480
2) 20480 / 65500 = 0 (16 bit math)
3) 0 - 2.5 = -2.5 (will hopefully convert to float)
If this is the case you can fix it with type casting :-
return ((float)(read_adc()*5)/65500)-2.5;
or even
return (read_adc()*5.0f/65500)-2.5;
Hope this helps.
wanabe
PostPosted: Wed Jan 06, 2010 8:45 am     Reply with quote
I change it a bit.
Now I get this error after I tried to compile the code..>>
...unknown device type --try PCM
I'm using PCW compiler.
#include<16F877A.h>
#device adc=10
#include <STDLIB.H>
int16 math ()
void main ()
setup_adc_ports( ANALOG_RA3_REF );
setup_adc( ADC_CLOCK_DIV_32 );
while (1)
   set_ADC_channel(0);
   delay_us(20);
   math();
   delay_us(5);
float math()
  return (read_adc()*5/1023)-2.5;
PostPosted: Wed Jan 06, 2010 9:32 am     Reply with quote
PCW, is the 'windows front end' for the compiler. Near the top of the screen, above the text 'Lookup part', you have which compiler is going to be used. PCB, PCM, PCH, PCD etc., for the different chip families.
Select PCM here.
Your function prototype, must _match_ what the function actually returns. Currently you have the prototype saying it returns an int16, and the actual function returning a float....
You are still not casting the arithmetic on the incoming value to a float, so will lose most values.
takumi
PostPosted: Thu Jan 07, 2010 12:11 am     Reply with quote
#include<16F877A.h>
#device adc=10
#include <STDLIB.H>
int16 math () ; // a function prototype must have ; after ()
void main(){
//your code
int16 math(){
//your code
