Microcode Bootloader with Bluetooth Serial Replacement
cap110874
PostPosted: Tue Jan 05, 2010 10:32 am     Reply with quote
Hello Folks - I am using a pic 18f2525 with the microcode bootloader and this has been working very well with a serial cable.
We have just been testing a bluetooth serial cable replacement module and this has been working very well with sending and receiving commands
BUT.......
will not work with the bootloader. It seems the bootloader is looking for he pic to reset and however many times I reset the pic it never recognises it. I think the delay in the bluetooth comms might cause this but this is only a guess. And suggestions or ideas would be very welcome.
Thanks Chris....
PostPosted: Tue Jan 05, 2010 2:44 pm     Reply with quote
This is a PicBasic issue and not related to CCS.
cap110874
PostPosted: Wed Jan 06, 2010 3:36 am     Reply with quote
Any idea if i could fix this or if the configuration file for the bootloader could be modified to help.
Do you think it is the latency on the bluetooth thats causing the problem.
Cheers guys
