74hc595 4 Digit 38mm C Driver !
yakuzaistanbul
PostPosted: Mon Jan 04, 2010 2:23 pm     Reply with quote
74hc595 serial connect C code please
Digital clock.
PostPosted: Mon Jan 04, 2010 2:46 pm     Reply with quote
Do you think we are your code slaves, to produce code on demand ?
We are all volunteers, working in industry or elsewhere. We like
to answer questions, but not to be code slaves.
yakuzaistanbul
PostPosted: Mon Jan 04, 2010 3:20 pm     Reply with quote
sorry
I want students to develop amateur lcd temperature display with clock and I did. I wanted to get help with segment I wanted to. lcd with the code
#include "16f628a.h"                //Mikrodenetleyici seçilir
#fuses    INTRC_IO, NOWDT, PROTECT, PUT, NOMCLR        //Sigortalar seçilir
#use    delay (clock=4000000)                  //Osilatör hızı belirlenir
#use    rs232(baud =4800, PARITY=N, xmit=PIN_A2, rcv=PIN_A1, BITS =8, ERRORS, STOP=2, STREAM = PORT1)
#use    I2C(master, slow, RESTART_WDT, sda=PIN_A7, scl=PIN_A6)
#define    LCD_EN            PIN_B0
#define    LCD_RS             PIN_B1
#define    LCD_RW             PIN_B2
#define    LCD_D4                PIN_B4
#define    LCD_D5                PIN_B5
#define    LCD_D6                PIN_B6
#define    LCD_D7                PIN_B7
#define    LINE_1                  0x00
#define    LINE_2                  0x40
#define    LCD_CLR_DISP          0X01 // Clear screen, home cursor, unshift display
#define    LCD_RETURN_HOME       0X02 // Home cursor, unshift display
#define    LCD_ENTRY_DEC          0X04 // Display shift off, dec cursor move dir
#define    LCD_ENTRY_DEC_SHIFT       0x05 // Display shift on, dec cursor move dir
#define    LCD_ENTRY_INC          0x06 // Display shift off, inc cursor move dir
#define    LCD_ENTRY_INC_SHIFT       0x07 // Display shift on, inc cursor move dir
#define    LCD_DISP_OFF          0x08 // Display off
#define    LCD_DISP_ON          0x0C // Display on, cursor off
#define    LCD_DISP_ON_BLINK       0x0D // Display on, cursor off, blink char
#define    LCD_DISP_ON_CURSOR       0x0E // Display on, cursor on
#define    LCD_DISP_ON_CURSOR_BLINK   0x0F // Display on, cursor on, blink char
#define    LCD_MOVE_CURSOR_LEFT       0x10 // Move cursor left (decrement)
#define    LCD_MOVE_CURSOR_RIGHT       0x14 // Move cursor right (increment)
#define    LCD_MOVE_DISP_LEFT       0x18 // Shift display left
#define    LCD_MOVE_DISP_RIGHT       0x1C // Shift display right
#define    LCD_FUNCTION_4BIT_1LINE      0x20 // 4-bit interface, single line, 5x7 dots
#define    LCD_FUNCTION_4BIT_2LINES   0x28 // 4-bit interface, dual line, 5x7 dots
#define    LCD_FUNCTION_8BIT_1LINE    0x30 // 8-bit interface, single line, 5x7 dots
#define    LCD_FUNCTION_8BIT_2LINES    0x38 // 8-bit interface, dual line, 5x7 dots
#define    LCD_CGRAM_BASE_ADDR       0x40 // Set the CGRAM address
#define    LCD_DDRAM_BASE_ADDR       0x80 // Set the DDRAM address
#define    LCD_LINE_1          0x80 // Position of start of line 1
#define    LCD_LINE_2          0xC0 // Position of start of line 2
#define    LCD_LINE_3          0x94 // Position of start of line 3
#define    LCD_LINE_4          0xD4 // Position of start of line 4
#define    LCD_DEGREE_CHAR       0x00 // Ascii 00
#define    LCD_TYPE          2 // 0=5x7, 1=5x10, 2=2 lines
void   Ds1307Init(void);
void   OkuDs1307(void);
void   InitTmp100(void);
void   OkuTmp100(void);
void      LCD_Init(void);
void      LCD_SetPosition(unsigned int);
void      LCD_PutChar(unsigned int);
void      LCD_PutCmd(Unsigned int);
void      LCD_PulseEnable(void);
void      LCDInit_PulseEnable(void);
void      LCD_SetData(unsigned int);
int   SicaklikTmp100Isaret=' ', SicaklikTmp100Basamak1, SicaklikTmp100Basamak2, SicaklikTmp100Basamak3;
int   SicaklikDegeri;
int   SayacRunLed1, SayacRunLed2;
int    Saniye, Dakika, Saat, HaftaGun, Aygun, Ay, Yil;
int   SaniyeAlt, SaniyeUst, DakikaAlt, DakikaUst, SaatAlt, SaatUst, HaftaGunAlt, HaftaGunUst;
int   AygunAlt, AygunUst, AyAlt, AyUst, YilAlt, YilUst;
int   BufferSaniye, SayacIkiNokta;
//#int_RTCC
//void   Timer9KesmeGeldi(void){
 //  if(SayacRunLed1==0){
 //     OkuDs1307();
 //     OkuTmp100();
 //  restart_wdt();
void   LCD_SetPosition(unsigned int cX){
   LCD_SetData(swap(cX) | 0x08 );
   LCD_PulseEnable();
   LCD_SetData(swap(cX) );
   LCD_PulseEnable();
void   LCD_SetData(unsigned int cX){
   output_bit(LCD_D4, cX & 0x01);
   output_bit(LCD_D5, cX & 0x02);
   output_bit(LCD_D6, cX & 0x04);
   output_bit(LCD_D7, cX & 0x08);
void   LCD_PulseEnable(void){
   output_high(LCD_EN);
   delay_us(10);
   output_low(LCD_EN);
   delay_ms(20);
void   LCDInit_PulseEnable(void){
   delay_us(10);
   output_low(LCD_EN);
   delay_ms(20);
void   LCD_PutCmd(unsigned int cX){
   LCD_SetData(swap (cX) );     /* send high nibble */
   LCD_PulseEnable();
   LCD_SetData(swap(cX) );     /* send low nibble */
   LCD_PulseEnable();
void   LCD_PutChar(unsigned int cX ){
          output_high(LCD_RS);
        LCD_SetData(swap(cX));     /* send high nibble */
   LCD_PulseEnable();
        LCD_SetData(swap(cX));     /* send low nibble */
        LCD_PulseEnable();
        output_low(LCD_RS);
void    LCDInit(void){
   LCD_SetData(0X00);
   delay_ms(400);       /* wait enough time after Vdd rise */
   output_low(LCD_RS);
   LCD_SetData(0X03);   /* init with specific nibbles to start 4-bit mode */
   LCDInit_PulseEnable();
   LCD_SetData(0x02);   /* set 4-bit interface */
   LCDInit_PulseEnable();      /* send dual nibbles hereafter, MSN first */
   LCD_PutCmd(0x2C);    /* function set (all lines, 5x7 characters) */
   LCD_PutCmd(0x0C);    /* display ON, cursor off, no blink */
   LCD_PutCmd(0x01);    /* clear display */
   LCD_PutCmd(0x06);    /* entry mode set, increment & scroll left */
void    OkuDs1307(void){
   i2c_stop();
   i2c_stop();
   i2c_start();
   i2c_write(0xD0);
   i2c_write(0x00);
   i2c_start();
   i2c_write(0xD1);
   Saniye   =i2c_read(1);
   Dakika   =i2c_read(1);
   Saat   =i2c_read(1);
   HaftaGun=i2c_read(1);
   AyGun   =i2c_read(1);
   Ay   =i2c_read(1);
   Yil   =i2c_read(0);
   i2c_stop();
   SaniyeAlt=(Saniye&0X0F)      ;
   SaniyeUst=((Saniye>>4)&0X07)   ;
   DakikaAlt=(Dakika&0X0F)      ;
   DakikaUst=((Dakika>>4)&0X07)   ;
   SaatAlt  =(Saat&0X0F)      ;
   SaatUst  =((Saat>>4)&0X07)   ;
   AyGunAlt =(AyGun&0X0F)      ;
   AyGunUst =((AyGun>>4)&0X07)   ;
   AyAlt    =(Ay&0X0F)      ;
   AyUst     =((Ay>>4)&0X07)   ;
   YilAlt   =(Yil&0X0F)      ;
   YilUst   =((Yil>>4)&0X07)   ;
   if(Saniye != BufferSaniye){
      SayacIkiNokta=250;
      BufferSaniye=Saniye;
void Ds1307Init(void){                   //Start biti ve konfigürasyon Çalışıyor
   int   Durum;
   i2c_stop();
   i2c_stop();
   i2c_start();
   i2c_write(0xD0);
   i2c_write(0x00);
   i2c_start();
   i2c_write(0xD1);
   Durum = i2c_read(0);
   i2c_stop();
   Durum &= 0x7F;
   i2c_start();
   i2c_write(0xD0);
   i2c_write(0x00);
   i2c_write(Durum);
   i2c_start();
   i2c_write(0xD0);
   i2c_write(0x07);
   i2c_write(0x92);
   i2c_stop();
   i2c_start();
   i2c_write(0xD1);
   i2c_stop();
void   OkuTmp100(void){
   int      DegerAlt, DegerUst, Temp;
   i2c_stop();
   i2c_stop();
   i2c_start();
   i2c_write(0X90);
   i2c_write(0X00);
   i2c_start();
   i2c_write(0X91);
   DegerUst = i2c_read(1);
   DegerAlt = swap(i2c_read(0));
   i2c_stop();
   if(bit_test(DegerAlt, 7) == 1){
      SicaklikTmp100Isaret = ' ';
      i2c_stop();
      i2c_stop();
      i2c_start();
      i2c_write(0X90);
      i2c_write(0X01);
      i2c_write(0X60);
      i2c_stop();
   else{
      if(bit_test(DegerUst, 7) == 0){
         SicaklikTmp100Isaret = '+';
         if(DegerUst<100){
            SicaklikTmp100Basamak3 = 0;
            SicaklikTmp100Basamak2 = DegerUst/10;
            SicaklikTmp100Basamak1 = DegerUst%10;
         else{
            SicaklikTmp100Basamak3 = 1;
            SicaklikTmp100Basamak2 = (DegerUst-100)/10;
      else{
         SicaklikTmp100Isaret = '-';
         bit_clear(DegerUst, 7);
         Temp = 127-DegerUst;
      SicaklikDegeri=   SicaklikTmp100Basamak3*100+SicaklikTmp100Basamak2*10+SicaklikTmp100Basamak1-1;
void main (void){
   set_tris_a(0Xff);    // a port giriş giriş olarak yönlendiriliyor
   set_tris_b(0X00);    // b port çıkış
   LcdInit();
        Ds1307Init();
 //  fprintf(PORT1,"Start",);
   LCD_SetPosition (LINE_1 + 0);
   printf (LCD_PutChar, "    Fatih    ");
   LCD_SetPosition (LINE_2 + 0);
   printf (LCD_PutChar, " Ortam Sicakligi  ");
//      enable_interrupts(INT_RTCC);
 // enable_interrupts  (GLOBAL);
   while(true){
         OkuTmp100();
         OkuDs1307();
  //      fprintf(PORT1,"%d  - \x0D\X0A ", SicaklikDegeri);
         printf(LCD_PutChar,"%c %d %d%d: %d%d: %d%d ", SicaklikTmp100Isaret, SicaklikDegeri,
        SaatUst,SaatAlt, DakikaUst,DakikaAlt, SaniyeUst,SaniyeAlt,);
         delay_ms(50);
          if(input(PIN_A5)==1){
         if(++DakikaAlt>9){
          DakikaAlt=0;
         if(++DakikaUst>5){
         DakikaUst=0;     }
         Dakika = ((DakikaUst<<4) | DakikaAlt);
         I2C_Start();
         I2C_Write(0xD0);
         I2C_Write(0x01);
         I2C_Write(Dakika);
         I2C_Stop();
