Joined: 17 Aug 2005 Posts: 316 Location: Perth, Western Australia
Problems with SIOW v4
Posted: Wed May 06, 2009 8:19 am
Is anyone using the new SIOW (Serial Input/Output Monitor)? I got version 4 with my updated 4.092 compiler, compared to the version 3 I got with my old 4.042 compiler.
The problem is that version 4 seems to be corrupting the data it receives - primarily by duplicating the data it receives in various ways. I spent ages thinking I'd introduced a bug before deciding to try the old v3 copy - where everything looks fine. _________________ Andrew
webbers Guest
siow problems
Posted: Mon Jan 04, 2010 7:38 am
I also have the same problem, for every line sent to siow - it prints it up twice.
rwskinner
Re: siow problems
Posted: Mon Jan 11, 2010 8:03 pm
Yes, and when turning off HEX mode, it will lock up and causing CPU to go to 50% or more.
