EEPROM programming
kazama
EEPROM programming
PostPosted: Sat Jan 02, 2010 10:55 pm     Reply with quote
Hello, I have a problem regarding EEPROM programming. I use CCS help section to search the write_eeprom() syntax. I want to know, do I need to set the bits for eeprom such as EEADR or any bits that are required to make eeprom writing work ? Or do I just use the write_eeprom(address,value) ?
CCS Version: 4.038
Current project: Obstacle detection robot
PostPosted: Sun Jan 03, 2010 4:09 am     Reply with quote
Just use write_eeprom.
The function does all the 'donkey work' for you.
This is the basic 'point' about CCS. The supplied functions (RS232, eeprom etc.), 'encapsulate' all the basic operations, so you don't have to worry about how your particular PIC does it. You can take a program written on a PIC16xxx, and provided you only use the standard functions, just change the header (processor include, fuses etc.), and reompile it to run on a PIC18, and it works. Smile
webgiorgio
PostPosted: Sun Jan 03, 2010 7:14 am     Reply with quote
write_eeprom(address,value);
Which address have I to use?
I have not understand looking to the datasheet.
I'm using a 16f876a and "value" is an int16.
tnx
PostPosted: Sun Jan 03, 2010 8:52 am     Reply with quote
Address, is up to _you_ (within the limitations of the chip).
If your chip has 256 bytes of EEPROM, address, is the number of the location in this you want to use. If you use address=0, the data will be written to the first byte in the EEPROM. Use address=255, and the data will be written to the last byte.
On chips with 1024 bytes of EEPROM, address can be 0 to 1023.
Think of the EEPROM, like a set of numbered pigeon holes. The address, is the number of the pigeon hole to use.
webgiorgio
PostPosted: Sun Jan 03, 2010 9:42 am     Reply with quote
looks very simple! Smile
Is a byte in the eeprom 8 bit right? so doing write_eeprom(0,value); I will write byte 0 and byte 1, right? (value is int16 type)
kazama
PostPosted: Sun Jan 03, 2010 10:19 am     Reply with quote
So if I use 16f877a with eeprom data memory 256 bytes.. the range of address is 0 - 255. For the syntax write_eeprom(address,value); the address can be use in hex form or not? eg: write_eeprom(0x00,value);. For the value if I declare the adc as var1 = read_adc(), so the value = var1.. eg: write_eeprom(0x00,var1);. Am I right?
thanks
CCS Version: 4.038
PostPosted: Sun Jan 03, 2010 11:21 am     Reply with quote
I think some reading on basic C, and numeric formats is needed....
Numbers inside the chip, are always _binary_ (nothing else). C handles automatically converting decimal, octal, or hex to this for you.
A 'byte' is always 8 bits.
Bit beans 'binary digit'. One digit of a binary value. A 'nibble' is four bits, and a byte is 8 bits.
