Drive a 2-digit segment with PIC18F4520 to display values
Posted: Wed Dec 23, 2009 10:32 am
I'm new to C programming. I need help on how to code the PIC to display the values.
yerpa
Posted: Wed Dec 23, 2009 11:40 am
If you are using the CCS compiler, you came to the right place. If you are using a different compiler, this forum will not be helpful. There are a lot of examples of programs for 7-segment displays, you will want to use the forum search or google search using google tricks like "site:ccsinfo.com/forum/" to find them. Learning the search methods will help with future questions, too.
Good luck!
olamigoke
7-segment diaplay to read and display digit values
Posted: Thu Dec 24, 2009 7:41 am
I tried to use the search but I could not find any project of 7-segment. Any help you can render about how to searching for the related codes will hihgly appreciated.
mskala
Joined: 06 Mar 2007 Posts: 100 Location: Massachusetts, USA
