lcd voltmeter
thinkpositivex
lcd voltmeter
PostPosted: Wed Dec 23, 2009 10:41 pm     Reply with quote
Hi all,
I'm new in this forum. I want to build the lcd voltmeter capable to display the 0-5v by using the LCD. I have already run the program as below and simulate using Proteus, but it not run well because my lcd only show 1.24 to 0 as I vary the potentiometer 2.5k. Plz help me.
Compiler 4.084
20MHz
LCD CONFIGURATION: refer LCD.C program
#include <LCD.C>
int16 adc_value;
float volts;
setup_adc (ADC_CLOCK_DIV_32);
setup_adc_ports(AN0);
set_adc_channel(0);
delay_us(10);
   adc_value = read_adc();
   volts = (float)(adc_value * 5)/1023.0;
   printf(lcd_putc, "VOLT:\f%3.2f", volts);
PostPosted: Wed Dec 23, 2009 10:58 pm     Reply with quote
I want to build the lcd voltmeter capable to display the 0-5v.
But my lcd only show 1.24 to 0.
That's because you left out part of the program that you got from here:
http://www.ccsinfo.com/forum/viewtopic.php?t=32168&start=1
You left out all these lines:
#include <16F877.H>
#device adc=10
Which line do you think is the cause of your problem ? Your ADC
result is only 1/4 of the expected range. If the ADC can be in 8 or 10
bit mode, what mode do you think you are running in ? Which line
as shown above is the important one to fix the problem ?
Basically, don't leave out lines of a program. Everything is important.
thinkpositivex
lcd voltmeter
PostPosted: Thu Dec 24, 2009 1:28 am     Reply with quote
[quote]: PCM programmer
thanks PCM programmer ...but for your information but i have alreadY compile the coding...but error happen
Program Files\PICC\devices\16F877.H appear
This is a program i compile,its true??Its true if i select the lcd driver before i open project wizard?means i import the lcd driver lcdd.c before i continued to do program
#include "C:\Documents and Settings\matz\My Documents\CCS\LCD VOLT 16F877\main.h"
#include <16F877.H>
#device adc=10
#include <LCD.C>
int16 adc_value;
float volts;
setup_adc(ADC_CLOCK_DIV_8);
set_adc_channel(0);
delay_us(20);
   printf(lcd_putc, "\f%3.2f", volts);
[/quote]
Rohit de Sa
PostPosted: Thu Dec 24, 2009 2:53 am     Reply with quote
I quote Ttelmah from a different thread:
Ttelmah wrote:
Layout should be:
First the processor include.
Then it's defines
Then fuses
Then clock
RS232 setup if being used.
Only now, other includes.
Follow this general program structure to avoid errors.
I think your problem lies in the program's first line:
What does this line do? What is the code in "main.h" ? You already have all the necessary includes and defines.
Rohit
thinkpositivex
lcd voltmeter
PostPosted: Thu Dec 24, 2009 3:48 am     Reply with quote
thank you very much2 Rohit..it work..but i hava a lot of question:-
1) why my lcd only measure 0.00 - 4.99.why it not up to 5.00..is it because in my program hava a divide by 1023.0
2) why my lcd not display a word VOLT: 0-5V when i added at the second last of my program
printf(lcd_putc, "VOLT: \f%3.2f", volts);
3)i have done a lot of research about the lcd voltmeter,i find that this lcd capable to measure the voltage higher than 5V by using the ratio..i'm not understand the ratio method can you explain to me.
4) can i develop the lcd current meter by using PIC ?
Rohit de Sa
PostPosted: Thu Dec 24, 2009 4:07 am     Reply with quote
Actually it should....but I'm really not too sure about this. I'll better let someone more competent answer this.
Look at the code. There is a "[b]\f[\b]". This [i]clears[\i] the LCD and then displays the float variable, 'volts'. Remove the "\f", and you should be able to see everything.
use a potential divider arrangement. This is also called a 'voltage divider'. http://en.wikipedia.org/wiki/Voltage_divider
There are several methods to measure DC current. You could use a 'sense resistor'. This is a very low value resistance put in series with the main circuit. Use an opamp to buffer the voltage drop across the sense resistor. This voltage can be correlated to current. For higher currents you can use a hall effect sensor.
Rohit
