SugarD Guest
Better Algorithm for driving Custom LCD? |
Posted: Wed Dec 23, 2009 11:13 pm |
Hi, I am using PIC 18F65J90, which has built in LCD driver, to drive custom designed LCD that consists of multiple digits of 7 segment LCD's.
The LCD displays not only the numbers but also some letters that I can display using 7 segments.
When one uses module LCD, I know he can display multiple letters on the module using relatively small ROM space. He can just write,
lcd_putc("AbCdEF");
However, when I have to write the same thing on the custom LCD, I have to write
lcd_symbol(digit_map[A], digit1);
lcd_symbol(digit_map[b], digit2);
lcd_symbol(digit_map[c], digit3);
lcd_symbol(digit_map[d], digit4);
lcd_symbol(digit_map[E], digit5);
lcd_symbol(digit_map[F], digit6);
which takes too much program memory if i want to put a lot of them.
Is there any way I do the same compactly with costing less program memory??
Thanks |
Posted: Wed Dec 23, 2009 11:25 pm |
Please don't start a new thread every time you have a new question on
using the 18F65J90 with 7-segment LCDs.
But to answer your question, look at the lcd_putc() function in this CCS
example file:
Quote: | c:\program files\picc\examples\ex_92lcd.c |
Also look at the lcd_putc() function in this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=32774&start=8
If you have any questions, add them to this thread or your earlier thread. |
SugarD Guest
i tried but.. |
Posted: Thu Dec 24, 2009 1:49 am |
Sorry, I thought that the two topics were different.
I looked at the post you referred and modified them to suit my purpose, which didn't work.
//main.c
#include<18F65J90.h>
#include<def_18F65J90.h>
#fuses intrc
#use delay(clock = 32000)
#define CLOCK_SPEED 32000
//****************DP*******G*********F*******E********D********C********B*******A***
#define DIGIT1 COM0+0, COM2+31, COM3+31, COM1+31, COM0+31, COM1+0, COM2+0, COM3+0
#define DIGIT2 COM0+2, COM2+1, COM3+1, COM1+1, COM0+1, COM1+2, COM2+2, COM3+2
#define DIGIT3 COM0+4, COM2+3, COM3+3, COM1+3, COM0+3, COM1+4, COM2+4, COM3+4
#define DIGIT4 COM0+6, COM2+5, COM3+5, COM1+5, COM0+5, COM1+6, COM2+6, COM3+6
const int8 DIGIT_MAP[10]= {0x3F, 0x06, 0x5B, 0x4F, 0x66, 0x6D, 0x7D, 0x27, 0x7F, 0x67};
// a b c d e f g h i j
const int8 Letter_map[22] = {0x77, 0x7C, 0x39, 0x5E, 0X79, 0X71, 0X00, 0X00, 0X04, 0X00,
// k l m n o p q r s t
0X00, 0X38, 0x00, 0x54, 0x5c, 0x73, 0x00, 0x50, 0x6d, 0x78,
// u v
0x1c 0x3e};
//#including function headers.
#include<key_check.h>
int lcd_pos = 0;
byte segments = 0;
void lcd_putc(char c) {
if(c=='\f')
lcd_pos=0;
else{
if((c>='0')&&(c<='9'))
segments=Digit_Map[c-'0'];
else if((c>='a')&&(c<='z'))
segments = Letter_Map[c - 'a'];
else if(c=='-')
segments = 0x40;
else if(c =' ')
segments = 0x00;
switch(lcd_pos){
case 1 : lcd_symbol(segments,DIGIT1); break;
case 2 : lcd_symbol(segments,DIGIT2); break;
case 3 : lcd_symbol(segments,DIGIT3); break;
case 4 : lcd_symbol(segments,DIGIT4); break;
lcd_pos++;
//Function used for initializing LCD
void LCD_init(void){
LCDPS = 0b0010100; //WFT = 0(Type A waveform), BIASMD = 0(1/4 bias),
//LCDA = 1(lcd drive module is active), WA = 1(write allowed), LP = 0000(prescaling = 8:1)
//LCDSEx definition
LCDSE0 = 0xFF; //SEG<7:0> All Segment control
LCDSE1 = 0B10011111; //SEG<15:8> do not use 11(pulse_out)
LCDSE2 = 0XFF; //SEG<23:16> All segment control
LCDSE3 = 0B11011101; //SEG<31:24>
LCDSE4 = 0B00000001;
//LCDCON setup
LCDCON = 0b10011011; // LCDEN = 1, /SLPEN = 1, WERR = 0,unimplemented, CS<1:0> = 00(Fosc/4), LMUX<1:0> = 11(use 4 commons)
LCDREG = 0B00111100;//Unemplemented, CPEN = 0, BIAS<2:0> = 111, MODE13 = 1, CKSEL<1:0> = 00(regulator disabled)s
void init_rtn(void){
lcd_init();
void main(void){
init_rtn();
printf(lcd_putc,"\fabcd");
When I run the code, the LCD only displays the first letter.
I think there is something wrong with my printf statement.
Thanks |
