bideshm
| Handle port B interrupt and show data on 7segments LED |
Posted: Wed Dec 16, 2009 4:56 am |
Hi All,
I am trying to handle port B interrupt which is written for 4*4 matrix keypad and simultaneously display enter value on 12 seven segments LED.
I used the B0 to B3 port pin for column and B4 to B7 for row. Please look at the below code.
| Code: | //Device file
#include <18F452.h>
#fuses HS, NOWDT, NOLVP, NOBROWNOUT, NOPROTECT, PUT
#use RS232 (baud=9600, parity=N, bits=8, xmit=PIN_C6, rcv=PIN_C7, errors, stream=RS232)
BYTE bPressedKey;
BYTE bKeyArrangement [4][3] = {'1', '2', '3',
'4', '5', '6',
'7', '8', '9',
'R', '0', 'O'};
//Functions prototypes
void KeyPadController( void );
BYTE GetPressedKey( void );
void ScanColumn();
byte changes;
int8 current;
current = input_b();
changes = last_b ^ current;
last_b = current;
//To handle key press event
if (bit_test(changes, 4) && !bit_test(last_b, 4))
row = 0; // zero based indexing
if (siCol1)
column = 0;
else if (siCol2)
column = 1;
else if (siCol3)
column = 2;
else if (siCol4)
column = 3;
else if (bit_test(changes, 5) && !bit_test(last_b, 5))
row = 1;
if (siCol1)
column = 0;
else if (siCol2)
column = 1;
else if (siCol3)
column = 2;
else if (siCol4)
column = 3;
else if (bit_test(changes, 6) && !bit_test(last_b, 6))
row = 2;
if (siCol1)
column = 0;
else if (siCol2)
column = 1;
else if (siCol3)
column = 2;
else if (siCol4)
column = 3;
else if (bit_test(changes, 7) && !bit_test(last_b, 7))
row = 3;
if (siCol1)
column = 0;
else if (siCol2)
column = 1;
else if (siCol3)
column = 2;
else if (siCol4)
column = 3;
return bKeyArrangement[row][column];
//Check whether any key event occurs
if( bKeyPressed )
// 0-9
if (48 <= bPressedKey && 57 >= bPressedKey)
//Call a function to put the value of the key to a buffer
//for display and increment index of the buffer by 1
//Set the value to 0 so that the condition become false
bKeyPressed = 0;
//Check whether the condition becomes true more than once
printf("%c\r\n", bPressedKey); //Its getting called more than once
ScanColumn();
void ScanColumn( void )
siCol1 = 1;
siCol2 = 0;
siCol3 = 0;
siCol4 = 0;
output_bit(PIN_B0, 0);
output_bit(PIN_B1, 1);
output_bit(PIN_B2, 1);
output_bit(PIN_B3, 1);
delay_ms(10);
siCol1 = 0;
siCol2 = 1;
siCol3 = 0;
siCol4 = 0;
output_bit(PIN_B0, 1);
output_bit(PIN_B1, 0);
delay_ms(10);
siCol1 = 0;
siCol2 = 0;
siCol3 = 1;
siCol4 = 0;
output_bit(PIN_B2, 0);
delay_ms(10);
siCol1 = 0;
siCol2 = 0;
siCol3 = 0;
siCol4 = 1;
output_bit(PIN_B3, 0);
delay_ms(10);
//Interrupt mechanism
#int_RB
void RB_isr (void)
//global variable detecting key events
bKeyPressed = 1;
//Get the exact pressed
bPressedKey = GetPressedKey();
//Main function
set_tris_b(0xF0);
delay_us(10); //ensure line has time to settle
IOCB = 0xF0;
last_b = input_b();
//enabling interrupts on B port
clear_interrupt(INT_RB);
enable_interrupts(INT_RB);
enable_interrupts(GLOBAL)
while (1)
KeyPadController();
//Display the data on the 7 segments
DisplayData();
My problem is that when I press any keys from the keypad the interrupt is getting called more than once and even unpredictable times. If I am not wrong then this is happening due to debouncing factor.
What should I do so that no interrupt is invoked when I press down the key. I need the interrupt only in the key up action and no key down is required.
PCH complier,
PIC18F452 micro-controller
MPLAB IDE 8.33 _________________ Bidesh Mukherjee
Software Engineer
Kolkata |
Posted: Wed Dec 16, 2009 12:56 pm |
| Quote: | #include <18F452.h>
IOCB = 0xF0;
The 18F452 does not have an IOCB register. Also, your program does not compile. Therefore, you are not really testing this code. |
| Re: Handle port B interrupt and show data on 7segments LED |
Posted: Thu Dec 17, 2009 12:40 am |
Hi All,
//Device file
#include <18F452.h>
byte last_b;
byte row;
byte column;
short int siCol1, siCol2, siCol3, siCol4;
int8 bKeyPressed = 0;
BYTE bPressedKey;
'4', '5', '6',
'7', '8', '9',
'R', '0', 'O'};
void ScanColumn();
byte changes;
int8 current;
last_b = current;
if (siCol1)
column = 0;
else if (siCol2)
column = 1;
else if (siCol3)
column = 2;
else if (siCol4)
column = 3;
row = 1;
if (siCol1)
column = 0;
else if (siCol2)
column = 1;
else if (siCol3)
column = 2;
else if (siCol4)
column = 3;
row = 2;
if (siCol1)
column = 0;
else if (siCol2)
column = 1;
else if (siCol3)
column = 2;
else if (siCol4)
column = 3;
row = 3;
if (siCol1)
column = 0;
else if (siCol2)
column = 1;
else if (siCol3)
column = 2;
else if (siCol4)
column = 3;
if( bKeyPressed )
// 0-9
bKeyPressed = 0;
ScanColumn();
siCol1 = 1;
siCol2 = 0;
siCol3 = 0;
siCol4 = 0;
delay_ms(10);
siCol1 = 0;
siCol2 = 1;
siCol3 = 0;
siCol4 = 0;
delay_ms(10);
siCol1 = 0;
siCol2 = 0;
siCol3 = 1;
siCol4 = 0;
delay_ms(10);
siCol1 = 0;
siCol2 = 0;
siCol3 = 0;
siCol4 = 1;
delay_ms(10);
#int_RB
void RB_isr (void)
bKeyPressed = 1;
//Main function
set_tris_b(0xF0);
last_b = input_b();
while (1)
KeyPadController();
//DisplayData();
Please note that I have commented out the DisplayData method and statement IOCB = 0xF0. I have modified the code so that the code can be compiled.
PCH complier,
MPLAB IDE 8.33 |
bideshm
Posted: Thu Dec 17, 2009 12:43 am |
Hi All,
Please pardon me as I have the modified the code as a guest member since I was unable to log in to the site.
Thanks, _________________ Bidesh Mukherjee
Software Engineer
Kolkata |
Posted: Thu Dec 17, 2009 2:41 pm |
I think it would be a lot easier to do this if you modified the CCS keypad
routines, so they just poll the keypad in a timer interrupt. Set the
timer to interrupt at some suitable rate, such as every 10 ms.
This thread provides some hints:
http://www.ccsinfo.com/forum/viewtopic.php?t=40557
Also, I remembered that Newguy has posted some interrupt-driven
keypad code in the Code Library forum. I haven't tested this.
http://www.ccsinfo.com/forum/viewtopic.php?t=19726 |
