rob Guest
Driver /help required for atmel AT45DB041B |
Posted: Thu Jan 30, 2003 11:34 pm |
Hi all
I am having little or no response from the chip. I am using the 8 pin device and currently cant even read the status so this makes the driver debugging very difficult. I have interfaced directly to an 16f877 using the hardware SP interface.
So if anybody has a driver i can share or some pointers please help.
thanks in advance
regards
Rob Sterling
___________________________
Original Post ID: 11145 |
Joe Heinrich Guest
Posted: Fri Jan 31, 2003 8:32 am |
:=Hi all
:=I am having little or no response from the chip. I am using the 8 pin device and currently cant even read the status so this makes the driver debugging very difficult. I have interfaced directly to an 16f877 using the hardware SP interface.
:=So if anybody has a driver i can share or some pointers please help.
:=thanks in advance
:=regards
:=Rob Sterling
Here is code I wrote using CCS 2.XXX and MPLAB 5.01(I think).
It gives you basic functionality.
//this is to develope code for spi to atmel 45db321 memory. 10-20-2001
//10.26.2001 this works for getting the status out of the
// memory so it should be easy to get spi working for
//the other commands.
#include <16f877.h>
#include <stdlib.h>
#DEVICE PIC16F877 *=16 ICD=TRUE
#use delay (clock=2457600)
#use fast_io(a)
#use fast_io(b)
#use fast_io(c)
#use fast_io(d)
#use fast_io(e)
#define flash_ready_busy_pin pin_c2
#define flash_cs_pin pin_d2
//flash commands for Atmel at45db321
#define main_read 0x52
#define read_buff1 0x54
#define read_buff2 0x56
#define main_to_buff1 0x53
#define main_to_buff2 0x55
#define main_to_buff1_compare 0x60
#define main_to_buff2_compare 0x61
#define write_buff1 0x84
#define write_buff2 0x87
#define buff1_to_main 0x83
#define buff2_to_main 0x86
#define main_write_thru_buff1 0x82
#define main_write_thru_buff2 0x85
#define page_erase 0x81
#define block_erase 0x50
#define status_reg 0x57
#define SSPCON 0x0014
#byte TRISC = 0x0087
#byte TRISD = 0x0088
#byte sspstat = 0x0094
#define bf 0
void cs_low();
int spi_write1(spi_data);
spi_write(spi_data);
void cs_low() //select the flash
output_low(flash_cs_pin);
void cs_high() //deselect and close flash
//might need to check sspstat,bf
output_high(flash_cs_pin);
main()
int flash_temp;
set_tris_c(0b11010111); //spi,timer1,tx,rx
set_tris_d(0b11111011); //memory control
setup_spi(spi_master|spi_h_to_l|spi_clk_div_4);
spi_write(0x57);
spi_write(0x55);
flash_temp=spi_read();
while (!bit_test(sspstat,bf));
cs_high();
cs_low();
spi_write1(write_buff1);
spi_write1(0x7f);
spi_write1(0xf8);
spi_write1(0);
spi_write1(11);
cs_high();
cs_low();
spi_write1(read_buff1);
spi_write1(0x7f);
spi_write1(0xf8);
spi_write1(0);
spi_write1(10);
spi_write1(10);
spi_write1(10);
flash_temp = spi_read();
spi_write1(10);
spi_write1(10);
cs_high();
cs_low();
spi_write(buff1_to_main);
spi_write1(0x7f);
spi_write1(0xf8);
spi_write1(0);
cs_high();
cs_low();
spi_write1(main_read);
spi_write1(0x7f);
spi_write1(0xf8);
spi_write1(0);
spi_write1(00);
spi_write1(00);
spi_write1(00);
spi_write1(00);
spi_write1(00);
return(spi_read());
Original Post ID: 11158 |
Charlie U Guest
Re: Driver /help required for atmel AT45DB041B |
Posted: Fri Jan 31, 2003 1:36 pm |
:=Hi all
:=thanks in advance
:=regards
:=Rob Sterling
Following the link below and dig deeper. This may have an answer to your problem.
Original Post ID: 11171 |
rob Guest
Posted: Tue Feb 04, 2003 12:20 am |
Hi
Thanks for the help - i found my problem it was thee spi setup i had
setup_spi(spi_master|spi_l_to_h|spi_clk_div_4); and spi-read();
and the fix is
setup_spi(spi_master|spi_h_to_l|spi_clk_div_4); and sip_read(0);
Original Post ID: 11253 |
