snowbell Guest
RS232 interrupts |
Posted: Mon Dec 14, 2009 9:27 am |
I've tried the example EX_SISR.c but it didn't seem to work properly for me. It doesn't print the characters which I entered through Hyperterminal. It only prints "Running..." and "Buffered Data =>". I tried printing an 'a' as shown in the code below, and it managed to print it only the first time I tried to do the interrupt. Anyone can help me with this? Thanks.
#if defined(__PCM__)
#include <18F2620.h>
#use delay(clock=12000000)
#elif defined(__PCH__)
#elif defined(__PCD__)
#fuses HS, NOWDT, NOPROTECT
#use rs232(baud=9600, UART1A)
#endif
#define BUFFER_SIZE 32
BYTE buffer[BUFFER_SIZE];
BYTE next_in = 0;
BYTE next_out = 0;
#int_rda
void serial_isr() {
int t;
buffer[next_in]=getc();
t=next_in;
next_in=(next_in+1) % BUFFER_SIZE;
if(next_in==next_out)
next_in=t; // Buffer full !!
#define bkbhit (next_in!=next_out)
BYTE bgetc() {
BYTE c;
while(!bkbhit) ;
c=buffer[next_out];
next_out=(next_out+1) % BUFFER_SIZE;
return(c);
void main() {
enable_interrupts(int_rda);
#if defined(__PCD__)
enable_interrupts(intr_global);
#else
enable_interrupts(global);
#endif
printf("\r\n\Running...\r\n");
// The program will delay for 10 seconds and then display
// any data that came in during the 10 second delay
do {
delay_ms(10000);
printf("\r\nBuffered data => ");
while(bkbhit)
putc( bgetc() );
putc('a');
} while (TRUE);
snowbell Guest
Posted: Mon Dec 14, 2009 10:12 am |
By the way, i'm using compiler version 4.057. Thanks. |
snowbell Guest
Posted: Tue Dec 15, 2009 12:25 am |
I've also tried this very simple code of receiving a char and then displaying it on HyperTerminal. It still doesn't display, the char that I entered in HyperTerminal. It can print "Start:" and only show 'a' the first time, after that, it seems to hang. Can anyone help please. Thanks.
#include <18F2620.H>
#fuses HS, NOWDT, NOPROTECT, PUT, BROWNOUT, NOLVP
char c;
printf("Start: ");
c = getc();
putc(c);
putc('a');
bkamen
Posted: Wed Dec 16, 2009 1:17 am |
it's always a good idea to TEST to see if there is a char in the RX buffer before doing a getc().
In CCS-C that's most easily accomplished with kbhit();
Also, what kind of data are you receiving, ASCII or binary?
LegolasMicrochip
Posted: Tue Dec 22, 2009 6:58 am |
It actually does not hang, in fact its waiting for the character. Until or unless it does not receive a new character it would keep waiting on the getc().
So if you would type a character through your hyperterminal then it would display 'a' again.
Also verify that your circuit is correct. |
to make it clearer and faster try this hack |
Posted: Tue Dec 22, 2009 4:43 pm |
// useless -> delay_ms(10000);
printf("\r\nBuffered data =>\r ");
do {
while(bkbhit)
{ putc( bgetc() ); putc('a'); }
} while (TRUE);
U only see the setup print out - once and the delay does NOTHING useful anyway IF the ISR is actually working - each line with CR U send will be on a line of its own - minus all the 'a's |
