Will this statement work ??
arunb
PostPosted: Sat Dec 12, 2009 1:35 am     Reply with quote
As per the code below , a high state on MMC_DI sets a bit while a low state clears the bit...correct ??
 shift_left(in,1,input(MMC_DI));
Now I need to modify the above statement so that a high on MMC_DI should clear the bit, while a low state sets the bit value.
How do I do this ??
thanks
a
FvM
PostPosted: Sat Dec 12, 2009 3:15 am     Reply with quote
Did you try a C bit inverting operator?
arunb
RE:
PostPosted: Sat Dec 12, 2009 3:27 am     Reply with quote
Will this work ??
shift_left(in,1,!input(MMC_DI));
How to do a C bit inversion ???
Re: RE:
PostPosted: Sat Dec 12, 2009 5:58 am     Reply with quote
Just ex. "bit inversio"
void Tproc1(){
 int1 bit1;
 int8 byte1;
 bit1 =~bit1;
 byte1 = ~(byte1&0x01)&~0x01;
FvM
PostPosted: Sat Dec 12, 2009 8:11 am     Reply with quote
Will this work ??
If you have a CCS compiler, you may want to check yourself.
Are you interested in programming or just chatting?
arunb
RE:
PostPosted: Sat Dec 12, 2009 9:41 am     Reply with quote
I was busy working on the problem.
I tried it, it doesn't seem to work (but its possible I may be missing out something). First I want to know if the approach is right.
is correct or ...
shift_left(in,1,~input(MMC_DI));
I am trying to get an MMC card working, I am using the driver in PICC folder, mmc_spi.c.
The problem is that the MMC_DI pin is connected through a npn transistor (used for level shifting from 3.3 V to 5 V). A common emitter amplifier configuration.
So a high on MMC_DI becomes a low on the amplifier output.
I am using a 18F4620 mcu. The system works when the MMC_DI pin is directly connected to the mcu pin a5. (in this case no modification to the driver code is required).
But I would like to use the amplifier instead of a direct connection, so I thought the code could be modified to invert the MMC_DI pin states.
arunb
FvM
PostPosted: Sat Dec 12, 2009 9:50 am     Reply with quote
The first is the correct syntax for one bit (logical inversion) and gives correct result with CCS C, I think. The second may work as well.
