i2c write never returns - RTC chip
rret
PostPosted: Thu Dec 10, 2009 3:39 pm     Reply with quote
I am using the following circuit. The RTC is hooked up to a 16F877A.
RC2 is !RESET
RC3 is SCL
RC4 is SDA
The following code (from PCM_PROGRAMMER) was modified by me. The 1st write never returns. Please, any ideas why?
#ifndef PCF8593_SDA
#define PCF8593_SDA        PIN_C4   //data
#define PCF8593_SCL        PIN_C3   //clock
#define PCF8593_NOTRESET    PIN_C2
#use i2c(master, sda=PCF8593_SDA, scl=PCF8593_SCL)
#ifndef PCF8593_WRITE_ADDRESS
#define PCF8593_WRITE_ADDRESS 0xA2
#define PCF8593_READ_ADDRESS  0xA3
// Register addresses
#define PCF8593_CTRL_STATUS_REG    0x00
// Commands for the Control/Status register.
#define PCF8593_START_COUNTING     0x00   //bit7 = 0   p.6
#define PCF8593_STOP_COUNTING      0x80   //bit7 = 1   p.6
void PCF8593_init(void)
//pulse NOTRESET-
  output_low(PCF8593_NOTRESET);  //as per 8593 DS
  //delay_ms(20);
  output_high(PCF8593_NOTRESET);
PCF8593_write_byte(PCF8593_CTRL_STATUS_REG,
                              PCF8593_START_COUNTING);
void PCF8593_write_byte(int8 address, int8 data)
disable_interrupts(GLOBAL);
i2c_start();
i2c_write(PCF8593_WRITE_ADDRESS);  // <======== NEVER RETURNS
i2c_write(address);
i2c_write(data);
i2c_stop();
   PCF8593_init();
PostPosted: Thu Dec 10, 2009 3:53 pm     Reply with quote
If it locks up on the i2c_write(), it's because that function checks the
SCL line for "clock stretching" by the slave device. If the SCL line
is held low permanently, i2c_write() will stay in an endless loop
while waiting for SCL to go high. It will lock up.
One way this could happen is if you left off the pull-up resistors
on the SCL (and SDA) lines. These pull-ups are a requirement of
the i2c bus. You can use 4.7K ohm resistors for the pull-ups.
i2c_start();
i2c_write(address);
i2c_write(data);
i2c_stop();
Also, if you're not using interrupts in your program, then delete those
two lines.
rret
did indeed need the pull-up resistors
PostPosted: Thu Dec 10, 2009 4:48 pm     Reply with quote
Thanks PCM_PROGRAMMER.
My circuit did indeed need the pull-up resistors.
I threw a couple of 4.6 k ohms in there and bingo! No more stuck at the write call.
Thanks again.
