| Guest
				| CAN Bus 11 bit addressing |
				|  Posted: Wed Dec 09, 2009 7:08 pm |   |
				| I am using a PIC18F4580 to read CAN packets from a motec M400 ECU.
 I don't have the code with me at the moment, but I seem to be having trouble reading any address from the ECU that is below 2048. So looks like I can only read 29 bit addressing. I know you can store an 11 bit value in a 29 bit space. But is there a way to specify that you only want to read an 11 bit address, just like you can specify if an address is basic or extended when using
  	  | Code: |  	  | can_putd(int32 id, int * data, int len,int priority, int1 ext, int1 rtr); |
 where int1 ext defines 11 or 29 bit.
 Many thanks
 Juan
