interrupts on 16f628a
filjoa
PostPosted: Mon Dec 07, 2009 5:54 pm     Reply with quote
Hi
I try use this PIC with interrupts.
On datasheet it have one external interrupt on pin RB3 and I like use it to connect a switch, but I like connect on other RB pins some leds.
Program work if I make some like this:
My problem stay on use interrupt on pin RB0 and call him to make my sequence.
int8 count = 0;
#int_ext
void int_rb0()
   count++:
void seq1()
Output_B(0b01000000);
Output_B(0b00100000);
Output_B(0b00010000);
void seq2()
Output_B(0b00000000);
Output_B(0b01100000);
Output_B(0b01110000);
Output_B(0b01111000);
   enable_interrupts(INT_EXT);
   setup_timer_2(T2_DIV_BY_1, 255, 1);
   setup_ccp1(CCP_PWM);
   set_pwm1_duty(0);  //0 até 255
if (count==0) seq1();
if (count==1) seq2();
if (count>=2) count=0;
Best regards
filjoa
PostPosted: Thu Dec 10, 2009 8:21 am     Reply with quote
Hi
Interrupts finally work fine but have a problem....
When I write this:
void seq1()
Output_B(0b00000001); delay_ms(200);
Output_B(0b00000100); delay_ms(200);
Output_B(0b00000010); delay_ms(200);
Output_B(0b00001000); delay_ms(200);
It don't work... I need write this way:
void seq1()
output_high(PIN_B7); output_low(PIN_B6);output_low(PIN_B5); output_low(PIN_B4); delay_ms(200);
output_low(PIN_B7); output_high(PIN_B6);output_low(PIN_B5); output_low(PIN_B4); delay_ms(200);
output_low(PIN_B7); output_low(PIN_B6);output_high(PIN_B5); output_low(PIN_B4); delay_ms(200);
output_low(PIN_B7); output_low(PIN_B6);output_low(PIN_B5); output_high(PIN_B4); delay_ms(200);
Someone can explain me why?
PS: It only occur on PIC16F628A because I try on PIC18F252 and this two ways work fine.
best regards
