DSPIC volume control
georpo
PostPosted: Fri Dec 04, 2009 5:36 am     Reply with quote
Hi all,
I have a project that plays back wav files stored in a microSD though the dspic audio dac.
Is there a way to control the volume in software so as to avoid the external trimmer?
yerpa
PostPosted: Fri Dec 04, 2009 10:34 am     Reply with quote
Before you output your sample to the DAC, multiply it by a number between zero and one. If the multiplier is near zero, the volume will be near zero, too. If the multiplier equals one, you get your full volume sample thru the DAC.
georpo
PostPosted: Mon Dec 07, 2009 12:36 am     Reply with quote
Thanks for the reply!
I do not get this. Between 0 and 1 there is only 0 and 1. So how can I be near 0 or near 1? Also keep in mind that my wav is signed, I read 2 bytes from the sd card and then make a 16 bit word that feeds the dac.
I guess that I should multiply the resulting 16bit word. Right?
bungee-
PostPosted: Mon Dec 07, 2009 1:35 am     Reply with quote
Multiply 16bit word with value between 0 and 1 means do it in float. You could also divide the value (same thing). Wink
SherpaDoug
PostPosted: Mon Dec 07, 2009 11:10 am     Reply with quote
Multiply by a byte from 0 to 255, then shift right 4 bits. The result is to get volume from 0 to 16X. No floats, no real divide.
georpo
PostPosted: Tue Dec 08, 2009 12:22 am     Reply with quote
OK, thanks for this. I will try it today! As about the first method, multiply with 0.5 for example, it takes up too much time of the cpu and I have to increase the clock to catch up with the sample rate.
I will try Multiply by a byte from 0 to 255, then shift right 4 bits and let you know. Thanks everybody!
georpo
PostPosted: Thu Dec 10, 2009 1:27 am     Reply with quote
Hi!
The multiply and shift method gives me distortion!
Below you can see a short version of the audio code:
int8 low_byte,high_byte;
int16 audio;
low_byte=spi_read(255);   //read low byte from SD card
high_byte=spi_read(255);  //read high byte from SD card
audio=make16(high_byte,low_byte);  // combine the 2 bytes to make 16bit word
while(bit_test(DAC1STAT,9));  // wait for dac fifo to empty
DAC1LDAT=audio;               // feed the dac
Please give me ideas for adjusting the volume.
Thanks.
PostPosted: Thu Dec 10, 2009 3:22 am     Reply with quote
It's most likely a problem of your implementation. The data has to be converted to int32 to multiply without overflow.
Also *255/16 can only give correct results for input magnitudes < 1/16 of full scale. Usually, a digital volume control
doesn't involve a gain > 1.
georpo
PostPosted: Thu Dec 10, 2009 4:05 am     Reply with quote
FvmM you are right.
I found it.
DAC1LDAT=(audio/100)*desired_volume
First I divide so the result fits in 16bits.
This way I have 100 steps of volume Smile
PostPosted: Thu Dec 10, 2009 6:19 am     Reply with quote
An you reduce 16 Bit CD quality to poor 9 bit Sad
The above suggested right shift (if applied correctly, with int32 intermediate result) is almost
keeping the sound quality and most likely introduces less computational effort than a divide operation.
If you are required to use a decimal percent factor, there are still ways to avoid a divide. You should particularly
consider, that dsPIC does fast multiply.
output = (int16)(((int32)input*655*n)>>16); { n = 0..100}
can be a possible replacement. With CCS compilers, the correct implementation of int16/int32
conversion should be checked thoroughly, there are many oddities, but it's basically O.K. with PCD, I think.
georpo
PostPosted: Thu Dec 10, 2009 7:36 am     Reply with quote
I tried this:
It works perfectly! Can you please explain the syntax of this?
And why *655?
PostPosted: Thu Dec 10, 2009 7:55 am     Reply with quote
The input is extended to int32 to allow succeding multiply without overflow. The basic idea is to replace /100 by *655/65536 (actually /100.05), where /65536 can be replaced by >>16 (shift right 16) respectively using the high word of an int32 structure.
