Bits and Bytes
richste
Bits and Bytes
PostPosted: Tue Dec 08, 2009 4:28 am     Reply with quote
Hello all,
I wonder if you can help me - I am trying to insert an extra bit into a printf RS232 output shown below:
int number=10;
printf(%c",number);
Output bit stream looks like 01010000.
What I want to do is be able to add a bit so that the output looks like this: 01011000. I am not sure how to go about it.
Adding a 1 with putc(1); creates a new byte so the output is
0101000010000000 which is not the output I am looking for.
I can't change "number" to include this 1 as it will be a variable.
I could well be doing this the wrong way - I am learning about RS232 and am only beginning to understand. Hopefully someone can help. Razz
Wayne_
PostPosted: Tue Dec 08, 2009 4:56 am     Reply with quote
OK, the bit stream is actually inverted so the value of 10 is actually
00001010 and you want to add the extra bit 00010000
You can do this by oring the 2 values
int number = 10; // in hex 0x0A
printf("%c", number | 0x10);  // 0x10 is hex for 00010000
// Will out put 0x1A or 00011010 bit stream = 01011000
richste
PostPosted: Tue Dec 08, 2009 5:20 am     Reply with quote
Thanks this works perfectly, it was a big help
