char * function parameter sendmessage(char *);
Alexandre Blais
PostPosted: Fri Jan 31, 2003 7:02 am     Reply with quote
I try to make a function who receive a char pointer, and it's doesn't work, this is my code.
void sendmessage(char *);
void sendmessage(char * string)
putc(STX);
printf(string);
putc(ETX);
sendmessage("Message test");
That is suppose do be very easy, with any normal compiler why it's doesn't work ?
___________________________
Original Post ID: 11154
R.J.Hamlett
Re: char * fonction parameter sendmessage(char *);
PostPosted: Fri Jan 31, 2003 7:16 am     Reply with quote
:=I try to make a fonction who receive a char pointer, and it's does'nt work, this is my code.
:=void sendmessage(char *);
:=void sendmessage(char * string)
:= putc(STX);
:= printf(string);
:= putc(ETX);
:=void main(void)
:= while(1)
:= sendmessage("Message test");
:=That is suppose do be very easy, with any normal compiler why it's does'nt work ?
The comment 'read the manual' applies...
Because of the architecture of the PIC, you can't have pointers to constants stored in ROM. The string if declared 'inline' like this, is stored as a constant table.
You can copy the string into a RAM array (in which case the code will work as given), or the code does have a 'cheat', where a function that expects a single character, will if called as:
function("string");
be called six times, with each character from the string in turn.
Original Post ID: 11156
Alexandre Blais
PostPosted: Fri Jan 31, 2003 9:20 am     Reply with quote
I have use Hi-tech picc and CC5X and this work very good like any other normal ansi c compiler. So theres any way to pass a string to a function this suppose to be a very basic thing.
Big limitation.
Original Post ID: 11160
Sherpa Doug
PostPosted: Fri Jan 31, 2003 4:15 pm     Reply with quote
:=I have use Hi-tech picc and CC5X and this work very good like any other normal ansi c compiler. So theres any way to pass a string to a function this suppose to be a very basic thing.
:=Big limitation.
I'll bet if you look at the code size you will find the other compilers go through some very painful gymnastics to use pointers to ROM on a PIC. It is not impossible, and Mr Hamlett gave you two ways it CAN be done. But the wizards who came up with the Harvard architecture the PIC is based on, decided long ago that such pointers SHOULD NOT be done.
I am just a lowly BSEE so I don't easily question the wizards.
Original Post ID: 11173
