HG25504, 256 x 128 GLCD with SED1330 controller problem
Goto page Previous  1, 2
Sergeant82d
There I go again....
PostPosted: Mon Nov 30, 2009 9:24 pm     Reply with quote
There I go again.... leaving out important information...
In my continuing efforts to get this thing working, I changed boards! I moved over to my Inex NX-877 Plus II board, which uses a 20MHz crystal.
OTOH, I tried it with the EasyPIC3 and 8 MHz, with less success, but still better than the past two days.
I thought the long jumpers I had initially may have changed the timing enough to affect performance, so I moved to the other board which has built in sockets instead of male pin headers. This allows me to use 4" wires instead of 18".
To continue (finally!), I have been trying out different shapes from the graphics library, text effects, etc., with consistent results:
Every 8th column is not displaying, EXCEPT where that column intersects a displaying item, it will kind of "drag" along, smearing for 2-3 pixels from the displaying line. Think of spikes on a scope trace.
Also, on strictly vertical lines, there is a parallel line 6 columns to the left, flashing and appearing to scroll downward.
Thanks for your time!
PostPosted: Mon Nov 30, 2009 10:04 pm     Reply with quote
Do you have the same problem as shown in this thread ?
http://www.ccsinfo.com/forum/viewtopic.php?t=34970
See the screenshot about 2/3'rds of the way down the thread of
a filled circle with lines in it.
Also, verify that your version of the SED1335.c driver doesn't have
the bug described in this post:
http://www.ccsinfo.com/forum/viewtopic.php?t=34970&start=15
That bug was fixed by CCS right around version 4.088 or 4.089.
Make sure you fix it, if your version has the bug.
Sergeant82d
Yes
PostPosted: Mon Nov 30, 2009 11:05 pm     Reply with quote
Yes, that is the same problem I am having. Looking over that thread (again), I added "L" at the end of the numbers, thinking I have read that would force them up from char to int. Is that correct? However, it has no effect on the display.
  glcd_circle(128L, 64L, 25L, yes, on);
    etc....
I had read that thread a couple of days ago, when I was first beginning to work on this display; since I didn't have *any* display at the time, I had not retained the error info he shared. It was one of many from which I snagged hints and bits from all over the Internet.
I don't have a clue where to begin tracking down address calculations. I'm not asking you (or any of you) to do this for me, but I don't even know what they look like yet! Some hints?
Thanks again
Edited: My driver did have the bug, and I corrected it per your code, no effect.
PostPosted: Tue Dec 01, 2009 5:37 pm     Reply with quote
It seems like a lot of people have trouble making the SED1335.c driver
work. I'm curious about that, so I ordered one of these lcds. I should
get it later in the week. I'll work on it some more at that time.
Sergeant82d
PostPosted: Tue Dec 01, 2009 7:35 pm     Reply with quote
I would be happy to pay for that LCD - I have seen a great many of your very helpful posts as I have been searching the archives and reading back posts.
PM me if you're interested.
PostPosted: Tue Dec 01, 2009 8:27 pm     Reply with quote
No. If a number of people have trouble with something, it becomes
sort of a "challenge". It becomes fun to solve it.
MikeP
PostPosted: Wed Dec 02, 2009 9:57 am     Reply with quote
I have this GLCD working.
Please check to make sure your driver file has this fix for the getData() function this post.
http://www.ccsinfo.com/forum/viewtopic.php?t=21096
Sergeant
Thanks!
PostPosted: Wed Dec 02, 2009 12:57 pm     Reply with quote
I'll try it as soon as I get home from my day job... I'll let you know how it works out.
Sergeant82d
IT WORKS!!!
PostPosted: Wed Dec 02, 2009 5:25 pm     Reply with quote
Whooo Hoooo!!!
That did it - changing the low to high in "GetData" and "GetCursorAddress" cleared it up!
Thanks very much - It would have taken me a long time (okay, probably NEVER) to figure that out. I sure wish I'd found that old post in my searches here and other places online!
Now to fiddle with timing to minimize the flickering look...
Thanks again!
Brad
Sergeant82d
PostPosted: Wed Dec 02, 2009 5:41 pm     Reply with quote
The flickering was a result of the constant re-drawing in a while(1) loop... commenting that out and I have nice, dark, non-flickering graphics!
Thanks very much for your help, MikeP! And to you too, PCM_Programmer! This place rocks!
Brad
P.S. - I added a post to the code library forum with all this info rolled up - hopefully it will make it easier for others in the future to get this driver going.
MikeP
PostPosted: Wed Dec 02, 2009 6:24 pm     Reply with quote
Yes it should be fixed by CCS. Every time I update it overwrites the driver with the bugs in it.
I pulled my hair out for days when i first started trying to use the sed1335.c driver.
I have been play with this GLCD for a few weeks now.
Here is some code I wrote to draw a bitmap.
The int8 rom sections are made with a perl program that i also wrote that reads a bmp format file and outputs an array ready to be pasted into the C program.
#include <16F887.h>
#device *=16, adc=8
#FUSES INTRC_IO                 //Internal RC Osc, no CLKOUT
#FUSES NOPUT                    //No Power Up Timer
#FUSES MCLR                     //Master Clear pin enabled
#FUSES BORV40                   //Brownout reset at 4.0V
#use delay(clock=8000000)
#define GLCD_WIDTH         256
#define GLCD_HEIGHT        128
#define GLCD_CHAR_WIDTH    8
#define GLCD_CHAR_HEIGHT   8
#define GLCD_RST           PIN_C3
#define GLCD_RD            PIN_E2
#define GLCD_WR            PIN_E1
#define GLCD_CS            PIN_E0
#define GLCD_A0            PIN_A0
#include "sed1335.c"
void writeBitmap( void );
void writePattern( char pattern );
int8 rom  pic_top[] = {
0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
0xD5, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x50, 0x00, 0x00, 0x00, 0x00, 0x44,
0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0x80, 0x00, 0x00, 0x00, 0xAA,
0xD5, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x00, 0x00, 0x00, 0xEE,
0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0xAA, 0x80, 0x00, 0x00, 0xAA,
0xD5, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x55, 0x00, 0x00, 0x00, 0x00,
0x7F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE,
0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x80, 0x7F, 0xFF, 0xFF, 0xFF, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x80, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x81, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x83, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x80, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x87, 0x00, 0x00, 0x00, 0x00, 0x01, 0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x8F, 0x00, 0x00, 0x00, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x8F, 0x00, 0x00, 0xFC, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x8F, 0x00, 0x01, 0xDE, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x8F, 0x00, 0x01, 0xBE, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
0x8F, 0x00, 0x01, 0xFE, 0x00, 0x01, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01,
int8 rom  pic_bottum[] = {
0xC0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x03,
void main (void)
int16 x,y;
glcd_init(ON);
writeBitmap();
while(TRUE) { delay_us(1); }
   int16 i,t = 0;
   setCursorAddress(GLCD_GRAPHICS_ADDR);
   glcd_sendCMD(GLCD_CMD_DISPLAY_WRITE);
   TGLCD_DATA
   for(i = GLCD_GRAPHICS_ADDR; i < GLCD_GRAPHICS_ADDR + 2048; ++i)
      glcd_sendByte(pic_top[t++]);
   t = 0;
   for(i = GLCD_GRAPHICS_ADDR + 2049 ; i <= GLCD_GRAPHICS_ADDR + 4096; ++i)
      glcd_sendByte(pic_bottum[t++]);
   int16 i;
   TGLCD_DATA
   for(i = GLCD_GRAPHICS_ADDR; i < GLCD_GRAPHICS_ADDR_END; ++i)
      glcd_sendByte(pattern);
Page 2 of 2
