problem with( CONST float )declaration + KALMAN filter code
eng.alamin
PostPosted: Sun Nov 29, 2009 2:20 pm     Reply with quote
Hello
I have this IMU driver I wanted to implement in CCS but a list of
error 48 "Expecting ( "
error 43 : " Expecting a declaration"
Error 27 : "Expression must evaluate to a constant"
 * Please refer to tilt.c by Trammell Hudson <hudson@rotomotion.com>. Original code
 * with extensive comments is available at http://www.rotomotion.com/downloads/tilt.c
 * The State Update Routine is called every dt seconds with a new gyro rate measurement
 * in degrees/second. Gyro reading and scaling is accomplished in a separete routine
 * prior to calling state_update.
 * The Kalman Update Routine is also called every dt seconds with a new angle measurement
 * in degrees. The angle measurement is the difference between the desired balance angle and the
 * angle derived from the accelerometer reading. Conversion and scaling of the accelerometer acceleration
 * data to an angle measurement is accomplished in a separate routine prior to calling kalman_update.
 * The accelerometer alone is not fast enough to balance the platform. The gyro is fast enough
 * and the rate data can be integrated to calculate angle, however, bias or drift of the integrated
 * gyro rate data over time makes them unusable on their own. The Kalman Filter fuses the
 * accelerometer data with the gyro data to effectively unbias the integrated gyro rate data
 * providing a better angle estimate than either the accelerometer or gyro on their own.
#include <math.h>
static const float dt = 0.0205;       //time in seconds between gyro rate measurements
#define      R_angle_PARAM      0.3      //Adjusts Kalman filter convergence speed
#define      Q_angle_PARAM      0.001   //Used in Q matix to set level of trust in accel
#define      Q_gyro_PARAM      0.006   //data relative to gyro; originally 0.001 & 0.003
static float   P[2][2] = {            //Covariance matrix
                    { 1, 0 },
                      { 0, 1 } };
static float Pdot[4];
float         angle = 0;            //angle state
float         q_bias = 0;            //gyro bias state
float         rate = 0;            //unbiased angular rate
static const float   R_angle   = R_angle_PARAM;
 static const float   Q_angle   = Q_angle_PARAM;   //Q matrix
 static const float   Q_gyro   = Q_gyro_PARAM;
//********************State Update Routine********************
//Called every dt seconds with a biased gyro measurement, it updates the
//current angle and rate estimate.
void  state_update(float q_m)                 //gyro measurement
   const float q = q_m - q_bias;            //unbias gyro measurement
   Pdot[0] = Q_angle - P[0][1] - P[1][0];      //Compute the derivative of the covariance matrix
   Pdot[1] = - P[1][1];
   Pdot[2] = - P[1][1];
   Pdot[3] = Q_gyro;
   rate = q;                           //Save unbiased gyro estimate
   angle += q * dt;                     //Update angle estimate
   P[0][0] += Pdot[0] * dt;               //Update covariance matirx
   P[0][1] += Pdot[1] * dt;
   P[1][0] += Pdot[2] * dt;
   P[1][1] += Pdot[3] * dt;
//********************Kalman Update Routine********************
//Called every time a new accelometer measurement is available,
//in this implementation every dt seconds
float      angle_err;
float      C_0;
void kalman_update(float angle_m)
   const float C_0 = 1;
   /* const float      C_1 = 0; */            //not used
   const float      PCt_0 = C_0 * P[0][0];      //+ C_1 * P[0][1] = 0
   const float      PCt_1 = C_0 * P[1][0];      //+ C_1 * P[1][1] = 0
   const float      E = R_angle + C_0 * PCt_0;   //Compute error estimate
   /*   + C_1 * PCt_1 = 0 */               //not used
   const float      K_0 = PCt_0 / E;         //Compute Kalman filter gains
   const float      K_1 = PCt_1 / E;
   const float      t_0 = PCt_0;            //Compute measured angle
   const float      t_1 = C_0 * P[0][1];      //and error in the estimate
   P[0][0] -= K_0 * t_0;
   P[0][1] -= K_0 * t_1;
   P[1][0] -= K_1 * t_0;
   P[1][1] -= K_1 * t_1;
   angle_err = angle_m - angle;
   angle   += K_0 * angle_err;               //Update state estimate
   q_bias   += K_1 * angle_err;
SO ,, guys what the problem is how i can convert it to ccs ?
PostPosted: Sun Nov 29, 2009 2:40 pm     Reply with quote
Do a search and replace, and delete 'const' in all the variable declarations.
eng.alamin
PostPosted: Sun Nov 29, 2009 3:33 pm     Reply with quote
thank you Sir
