RF Module Help |
Posted: Sun Nov 29, 2009 8:21 am |
I am using the following code for RX
Code: | //Eg1
#include<16F877A.h>
#use delay(clock=20M)
#define WireTX PIN_C6 // <--------- C 6
#define WireRX PIN_C7
#include<LCD420.C >
#use rs232(baud=1200, xmit=PIN_C6, rcv=PIN_C7)
char data;
lcd_init();
output_high(pin_b3);
while(1) {
if ( kbhit() )
data = getc();
printf(lcd_putc,"\f%c",data,data);
and for TX
Code: | #include <18F2550.h>
//#define __USB_PIC_PERIF__ 1
#fuses HSPLL,NOWDT,NOPROTECT,NOLVP,NODEBUG,USBDIV,PLL5,CPUDIV1,VREGEN
//#include <usb_cdc.h>
int a;
// usb_init();
while (true)
// if (usb_enumerated())
putc('A');
putc('B');
putc('C');
The receiver lcd show some other values....
Please help me....
Thanks |
Posted: Sun Nov 29, 2009 9:38 am |
There may be a problem with the RF module, but as far as I understand, it's impossible by design to have a clock
frequency of 20 MHz in HSPLL operation mode. In this case, the TX UART frequency is also different from intended
1200 baud. Available frequencies are 16, 24, 32 and 48 MHz.
To get any help with RF module issues, you should at least mention the module type...
P.S.: CPUDIV1 means 48 MHz Clock (96 MHz/2) |
anandpv2009
Posted: Sun Nov 29, 2009 12:21 pm |
Quote: | But pickit2's frequency is 20mhz... |
You may want to learn the difference between crystal and CPU clock frequency. |
Posted: Tue Dec 01, 2009 4:24 pm |
From what I can see from the Vega-site, these are very basic RF modules without any built-in protocol. Such radio links can not be treated as a "wire" between the PIC's.
A good tip is sending packets, starting with 1-3 bytes as preamble so the receiver can "sync" to the transmitters bitrate. Also include a checksum so you can discard packets with errors.
If that´s too much work - try more advanced transceivers that come with this kind of protocol already in their own uP.
Good luck
/BdeB |
