Pull up resistor
Pull up resistor
PostPosted: Thu Nov 26, 2009 11:12 am     Reply with quote
I want to know the pins of pic18f250 and 18f2550 requires external pull up resistors
I know RA4 need one, but what about other pins.
John P
PostPosted: Thu Nov 26, 2009 11:52 am     Reply with quote
Huh. Difficult problem. What did you find when you read the manual?
PostPosted: Thu Nov 26, 2009 12:23 pm     Reply with quote
r u jocking...
bkamen
PostPosted: Thu Nov 26, 2009 12:26 pm     Reply with quote
Probably not.
The Datasheet for any PIC processor (barring doc errors) will tell you everything you need to know.
You want to look in the section for I/O Ports.
Cheers,
-Ben
PostPosted: Thu Nov 26, 2009 12:39 pm     Reply with quote
To find this information, look in the PIC's data sheet, in the
Device Overview section. Look at the pinout tables in that section:
TABLE 1-2: PIC18F2455/2550 PINOUT I/O DESCRIPTIONS
If an i/o pin says "Open Drain" in the description, it means that the pin
can only be set to a low level. The PIC can't drive it high.
If you want the pin to have the ability to go to a high level, then you
must add an external pull-up resistor to it. Then call the output_float()
function and the pull-up resistor will take it to a high level.
A typical description for an Open Drain pin in the Overview section will
look like this:
Output is open drain type.
or this
Open drain when configured as output.
Notice that the 18F2550 does not have that description for pin RA4.
PostPosted: Thu Nov 26, 2009 3:08 pm     Reply with quote
look like this:
or this
Thanks u for your reply
PostPosted: Thu Nov 26, 2009 3:12 pm     Reply with quote
one more doubt
Selection of any I2C mode with the SSPEN bit set
forces the SCL and SDA pins to be open-drain,
from data sheet
what it means...
I am not using I2C mode...Is there any need of pull-up resistors ..
PostPosted: Thu Nov 26, 2009 3:58 pm     Reply with quote
Basically no, but it depends what you are actually doing with the pin.
So (for instance), if you are using a pin as an input, and want it to float to a 'known' level, then pull-ups are needed.
Similarly, if using I2C, then they are needed.
Similarly, if you want to implement your own 'wire-or' strategy, then pull-ups become needed.
If you need to ensure that a pin when 'high', goes to a higher level than the data sheet warrants a output to drive 'up' to, then pull-ups are needed (common when driving some types of 5v logic from 3.3v chips).
A few pins (A4, on some PICs), do not have an internal high drive ability.
In each case, the data sheet shows the drive capabilities and levels involved.
If you are using a normal pin as a conventional output, then, 'no'.
