incoming dtmf tone in gsm
picfreak
PostPosted: Wed Nov 25, 2009 3:54 am     Reply with quote
Dialer B gsm module side I'm interfacing pic16f877a.
Dialer A called to dialer b. Dialer B attend the call of dialer A. At that time dialer A pressed any number in the other end. How can dialer B can detect that dtmf tone? Pls help me out how to detect an
Mark W
MT8889
PostPosted: Wed Nov 25, 2009 5:31 pm     Reply with quote
Check out the MT8889 chip. There is a driver in the driver library.
Cheers
Mark
picfreak
PostPosted: Thu Nov 26, 2009 2:44 am     Reply with quote
I am using 4.084 version.
In driver library there is no driver FOUND MT8889.
HELP ME OUT
PostPosted: Thu Nov 26, 2009 10:48 am     Reply with quote
Oh good lord, are you that much of a 'babe in the woods'? Do you require that we totally 'spoon feed' you??
Do a Forum search for 'MT8889'. You'll find the referenced driver in the Forum Code Library. This is a user-provided driver, not a CCS-provided driver.
You did do a forum search for 'DTMF' before your original post, right??
Seth
