Futterama
Problem with simple subtraction operator in if-statement |
Posted: Wed Nov 25, 2009 3:33 pm |
I was writing some code for PIC10F222 and came across this problem.
I was trying to subtract a variable from a static value before a comparison in an if-statement.
int8 test1;
int8 test2;
int8 test3;
test1 = 100;
test2 = 100;
test3 = 1;
if(test1 > (100-1))
GP0 = 1;
GP0 = 0;
The above code will put GP0 high. But if I replace (100-1) with (100-test3) GP0 will not be put high:
int8 test1;
int8 test2;
int8 test3;
test1 = 100;
test2 = 100;
test3 = 1;
if(test1 > (100-test3))
GP0 = 1;
GP0 = 0;
Did I do something wrong here? I guess the compiler will calculate (100-1) to be 99 and just insert this value in the code. But since test3 is 1 and 100-1 is 99, the result should be the same, right?
I'm using version 4.093.
Please help  |
Posted: Wed Nov 25, 2009 3:48 pm |
Not quite.
First, you need to have a while....true or similar at the end of your code to prevent the code dropping off the end.
As it stands, in the first case, the compiler will 'optimise' the test away, since the values are constants, and just insert the single line, setting GP0.
In the second, the lines can't be optimised away, since variables are being used, and these might be changed by something else. The test should evaluate to the same result, but the timing will be fractionally different.
Now, what you show shouldn't work at all, since you are not showing the TRIS being changed to make the pin an output, and are accessing the pin directly, bypassing the compiler's output functions.
I suspect if you avoid the drop off the end, and use the standard functions, it'll work fine:
int8 test1;
int8 test2;
int8 test3;
test1 = 100;
test2 = 100;
test3 = 1;
output_high(PIN_B0);
output_low(PIN_B0);
while (TRUE);
Futterama
Posted: Wed Nov 25, 2009 3:56 pm |
Well, I must have trimmed my code too much then. Full .c file:
Code: | #include "test.h"
int8 test1;
int8 test2;
int8 test3;
ANS1 = 1; // GP1/AN1 configured for analog input
ANS0 = 0; // GP0/AN0 configured as digital I/O
set_tris_b(0b11111010); // Set pin directions (GP0, GP2 = Output --- GP1, GP3 = Input)
GPIO = 0; // Reset all pins to low
test1 = 100;
test2 = 100;
test3 = 1;
GP0 = 1;
GP0 = 0;
Full .h file:
Code: | #include <10F222.h>
#device adc=8
#FUSES NOMCLR //Master Clear pin used for I/O
#FUSES NOMCPU //Master Clear Pull-up disabled
#FUSES IOSC8 //INTOSC speed 8MHz
#use delay(clock=8000000)
#use fast_io(b)
#use rs232(baud=2400, xmit=PIN_B2)
#byte GPIO = 0x06
#bit GP0 = GPIO.0
#bit GP1 = GPIO.1
#bit GP2 = GPIO.2
#bit GP3 = GPIO.3
#byte TMR0 = 0x01
#byte ADCON0 = 0x07 // A/D CONVERTER 0 REGISTER
#bit ANS1 = ADCON0.7 // ADC Analog Input Pin Select bit
#bit ANS0 = ADCON0.6 // ADC Analog Input Pin Select bit
//#bit 5: Unimplemented: Read as 0
//#bit 4: Unimplemented: Read as 0
#bit CHS1 = ADCON0.3 // ADC Channel Select bits
#bit CHS0 = ADCON0.2 // ADC Channel Select bits
#bit GODONE = ADCON0.1 // ADC Conversion Status bit
#bit ADON = ADCON0.0 // ADC Enable bit
#byte ADRES = 0x08 // ANALOG CONVERSION RESULT REGISTER |
Also I tested with your code, it's the same problem  |
Futterama
Posted: Wed Nov 25, 2009 4:17 pm |
Will a piece of the .lst file help?
Code: | .................... test1 = 100;
000B: MOVLW 64
000C: MOVWF 0C
.................... test2 = 100;
000D: MOVLW 64
000E: MOVWF 0D
.................... test3 = 1;
000F: MOVLW 01
0010: MOVWF 0E
.................... if(test1 > (100-test3))
0011: MOVF 0E,W
0012: BSF 04.5
0013: BSF 04.6
0014: SUBWF 04,W
0015: SUBWF 0C,W
0016: BTFSC 03.2
0017: GOTO 01C
0018: BTFSS 03.0
0019: GOTO 01C
.................... GP0 = 1;
001A: BSF 06.0
.................... else
001B: GOTO 01D
.................... GP0 = 0;
001C: BCF 06.0
.................... while(1);
001D: GOTO 01D |
I don't know ASM code, but I don't see any GOTO 01A where the GP0=1 is. |
John P
Posted: Thu Nov 26, 2009 12:53 am |
The jump to GP0 = 1 is made in line 0018, BTFSS 03.0. That means "Test bit and skip next instruction if bit is set", and 3.0 is the carry bit, which gets set if a quantity is subtracted from the W register leaving a negative or zero result (I think that's right). So if you skip around a GOTO (that's line 0019) you end up at line 20. But what that earlier stuff is all about, I don't know. My guess is that it's what happens if you do math on signed 8-bit numbers. |
Posted: Thu Nov 26, 2009 1:50 am |
I checked with MPLAB simulator and found, that the reported faulty behaviour is still present with PCB V4.100, but not e.g. in PCM. It's one of various cases, where a new bug has been introduced in CCS C V4, V3.224 is handling the code correctly. |
Futterama
Posted: Thu Nov 26, 2009 1:52 am |
Oh I see.
Signed? According to my understanding, int8 is default unsigned... |
Futterama
Posted: Thu Nov 26, 2009 1:54 am |
FvM wrote: | I checked with MPLAB simulator and found, that the reported faulty behaviour is still present with PCB V4.100, but not e.g. in PCM. It's one of various cases, where a new bug has been introduced in CCS C V4, V3.224 is handling the code correctly. |
Well, I don't think I really need V4 so perhaps I should go back to V3.224 if this has fewer bugs? |
Posted: Thu Nov 26, 2009 4:17 am |
The listing shown looks totally 'screwed'. You have 'test3', transferred to the W register (sensible), then the code sets bits 5, and bits 6, in the FSR. Now the data sheet says:
"FSR <7:5> are unimplemented and read as ‘1’s",
so setting these makes no sense at all.
It then behaves as if it now thinks the FSR register, is the INDF register, and now addresses the required byte. It doesn't...
The complexity is not signed arithmetic, it is just how to address a second register, while holding a value from another. The technique is 'right', but the address being put into the FSR, is wrong, and it is then using the wrong register to access the result...
I'd go back to an older working compiler, and 'scream'. Fortunately, it is nicely demonstrable.....
It is not V4, that has the problem. The code gives totally sensible results in an older V4 compiler, like V4.07x. However it uses an extra scratch RAM location to perform the arithmetic. It appears that CCS are trying to optimise RAM space in these small chips, by performing the maths using the FSR, without another register, but have just got the workings of it 'wrong'....
Posted: Thu Nov 26, 2009 4:19 am |
Quote: | My guess is that it's what happens if you do math on signed 8-bit numbers. |
The result is incorrect for any possible combination of signed or unsigned.
Quote: | According to my understanding, int8 is default unsigned... | Yes, according to the manual - and actually.
Quote: | perhaps I should go back to V3.224 if this has fewer bugs? |
Not generally. But I also have a few applications that must be frozen with V3. I don't know, if it's due to bugs or incompatible changes. Practically, the difference doesn't matter much.
Obvious bugs should be corrected, of course. But in practice, you perform a workaround. Possibly, you report the bug to CCS. After that, you won't check with every new version, if the bug is continued and the sparse revision history most likely doesn't tell. |
