convert Decimal to Hex
Goto page 1, 2  Next
nemero16
PostPosted: Sat Nov 21, 2009 7:45 pm     Reply with quote
Hi, I have written a program in C which writes an eeprom with uart, but I want to write address in decimal and not hex. When I use the uart command R and W ...example: read or write?:r block:125(instead of writing 7D) byte:AABBCCDD... as I can do? This is the code:
main.c :
#include <16F876.h>
#device adc=8
#FUSES HS                       //High speed Osc (> 4mhz for PCM/PCH) (>10mhz for PCD)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=seriale1)
#use i2c(Master,Fast,sda=PIN_C4,scl=PIN_C3)
#include "input.c"
#include "2416.c"
{BYTE *value[4], cmd;
   EEPROM_ADDRESS address;
   unsigned long int x;
   init_ext_eeprom();
   do {
      do {
         printf("\r\Read or Write?: ");
         cmd=getc();
         cmd=toupper(cmd);
         putc(cmd);
      } while ( (cmd!='R') && (cmd!='W') && (cmd!='T') );
     if((cmd!='R') && (cmd!='W')){
     else{
     printf("\n\rBlock: ");
#if sizeof(EEPROM_ADDRESS)==1
      address = gethex();
#else
#if EEPROM_SIZE>0xfff
      address = gethex();
#else
      address = gethex1();
      address = (address<<8)+gethex();
#endif}
    if(cmd=='R'){
     unsigned int i;
     unsigned int n=4;
     READ_EXT_EEPROM( address, n);
       printf("\r\nByte: ");
         for (i=0; i<n; i++) {
           printf("%X", data[i]);
         printf("\r\n");
    if(cmd=='W'){
     unsigned int i;
     unsigned int n=4;
         for(i=0; i<n; i++){
         value[i]=gethex();}
         WRITE_EXT_EEPROM( address, value, n);
          printf("\r\n");
    if(cmd=='T'){
     int i;
     unsigned int8 a;
     unsigned int max_memory=128;
     int n_byte_letti=4;
       printf("\r\n");
       printf("\r\n");
       for (a=0; a<max_memory; a+=n_byte_letti) {
       read_total_ext_eeprom(a, n_byte_letti);
       printf("%u%c",a,')');
       for (i=0; i<n_byte_letti; i++) {
       printf(" ");
     printf("\r\n");
     } while(true);
and this is 2416.c:
#ifndef EEPROM_SDA
#define EEPROM_SDA  PIN_C4
#define EEPROM_SCL  PIN_C3
#use i2c(master, sda=EEPROM_SDA, scl=EEPROM_SCL)
#define EEPROM_ADDRESS unsigned int8
#define EEPROM_SIZE    1024
BYTE data[4];
void init_ext_eeprom() {
   output_float(EEPROM_SCL);
   output_float(EEPROM_SDA);
int1 ext_eeprom_ready() {
   int1 ack;
   i2c_start();            // If the write command is acknowledged,
   ack = i2c_write(0xa0);  // then the device is ready.
   i2c_stop();
   delay_ms(10);
   return !ack;
void write_ext_eeprom(EEPROM_ADDRESS address, BYTE *data[4], unsigned int n_byte)
{int i;
if (n_byte>4) n_byte=4;
if (n_byte==0) return;
   while(!ext_eeprom_ready());
   i2c_start();
   i2c_write(0xa0);
   i2c_write(address);
for(i=0; i<n_byte; i++){
i2c_write(data[i]);}
i2c_stop();
delay_ms(10);}
void read_ext_eeprom(EEPROM_ADDRESS address, unsigned int n_byte)
{int i;
   i2c_start();
   i2c_write(0xa0);
   i2c_write(address);
   i2c_start();
   i2c_write(0xa1);
for (i=0; i<n_byte; i++) {
data[i]=i2c_read(1);}
i2c_stop();
delay_ms(10);
return;
void read_total_ext_eeprom(EEPROM_ADDRESS address, unsigned int n_byte)
{int i;
   i2c_start();
   i2c_write(0xa0);
   i2c_write(address);
   i2c_start();
   i2c_write(0xa1);
i2c_stop();
delay_ms(10);
return;
PostPosted: Sat Nov 21, 2009 9:29 pm     Reply with quote
This CCS driver file has routines to get input from a terminal in other
ways than just Hex format. For example, you can get a number in
decimal integer format. Here is the file location:
c:\program files\picc\drivers\input.c
Also, it looks like you have modified the external eeprom routines,
and you have made mistakes. If you need routines to read and write
to an external eeprom, look in this file:
c:\program files\picc\drivers\external_eeprom.c
Use the CCS routines. That's why CCS included them with the compiler -
To make it easier to do the things you need.
nemero16
PostPosted: Sun Nov 22, 2009 6:21 am     Reply with quote
Yes, I have modified the library to add an EEPROM array... can you tell me where I made mistakes? I analyzed the input file that is included in my program but I do not know how to set it ... give me some help?
PostPosted: Sun Nov 22, 2009 10:39 am     Reply with quote
In various places you have defined an array of pointers and it's clear
that you don't want an array of pointers, you want an array of bytes.
Get rid of the '*' in all your array declarations.
i2c_stop();
delay_ms(10);
return;
In this function you are reading 4 bytes, but don't have a "NACK" on
the last read in the sequence. This NACK is required by the i2c
specification. In CCS, a NACK is done by giving the i2c_read() function
a parameter of 0.
Also, functions return automatically. You don't need a return statement
at the end.
nemero16
PostPosted: Sun Nov 22, 2009 12:18 pm     Reply with quote
mmm ok I have removed all the "*", although I've set for reading i2c_read (1) function I have no problem, if imposed i2c_read (0) function works the same? to convert from decimal to hex as I set the gethex ()?
PostPosted: Sun Nov 22, 2009 3:22 pm     Reply with quote
You have created your own (buggy) routines to read and write 4 bytes to
eeprom. You don't need to do that. CCS has routines to do this.
These routines are in the external_eeprom.c file:
write_int32_ext_eeprom()
read_int32_ext_eeprom()
If you want to get the address in decimal, then use the get_int()
or get_long() routines in the input.c file. Use one of those routines
instead of the get_hex() routines.
nemero16
PostPosted: Sun Nov 22, 2009 3:35 pm     Reply with quote
But there is this in input.c file, but not get_int ():
#include <ctype.h>
BYTE gethex1() {
   char digit;
   digit = getc();
   putc(digit);
   if(digit<='9')
     return(digit-'0');
     return((toupper(digit)-'A')+10);
BYTE gethex() {
   unsigned int8 lo,hi;
   hi = gethex1();
   lo = gethex1();
   if(lo==0xdd)
     return(hi);
     return( hi*16+lo );
void get_string(char* s, unsigned int8 max) {
   unsigned int8 len;
   char c;
   --max;
   len=0;
   do {
     c=getc();
     if(c==8) {  // Backspace
        if(len>0) {
          len--;
          putc(c);
          putc(' ');
          putc(c);
     } else if ((c>=' ')&&(c<='~'))
       if(len<=max) {
         s[len++]=c;
         putc(c);
   } while(c!=13);
   s[len]=0;
// stdlib.h is required for the ato_ conversions
// in the following functions
#ifdef _STDLIB
#if !defined(__PCD__)
signed int8 get_int() {
  char s[5];
  signed int8 i;
  get_string(s, 5);
  i=atoi(s);
  return(i);
#if defined(__PCD__)
signed int16 get_int() {
  char s[5];
  signed int16 i;
  get_string(s, 7);
  i=atoi(s);
  return(i);
signed int16 get_long() {
  char s[7];
  signed int16 l;
  get_string(s, 7);
  l=atol(s);
  return(l);
signed int32 get_long() {
  char s[7];
  signed int32 l;
  get_string(s, 10);
  l=atoi32(s);
  return(l);
float get_float() {
  char s[20];
  float f;
  get_string(s, 20);
  f = atof(s);
  return(f);
PostPosted: Sun Nov 22, 2009 3:49 pm     Reply with quote
Look more closely.
nemero16
PostPosted: Sun Nov 22, 2009 3:53 pm     Reply with quote
ops... Very Happy I had not seen .. hahaha, but writing this out an error ...:
address = get_int();
PostPosted: Sun Nov 22, 2009 4:19 pm     Reply with quote
Read the input.c file comments above the get_int() function. It says:
This means you have to include the stdlib.h file, as shown below:
#include <stdlib.h>
#include "input.c"
#include "2416.c"
nemero16
PostPosted: Sun Nov 22, 2009 4:34 pm     Reply with quote
compiles ok but the program does not work because when I enter the address in dec and it does not go on .... this is the code:
#include <16F876.h>
#device adc=8
#include <stdlib.h>
#include "input.c"
#include "2416.c"
{BYTE value[4], cmd;
   unsigned int8 address;
   init_ext_eeprom();
   do {
      do {
         printf("\r\nLeggi o Scrivi?: ");
         cmd=getc();
         cmd=toupper(cmd);
         putc(cmd);
      } while ( (cmd!='L') && (cmd!='S') && (cmd!='T') );
     if((cmd!='L') && (cmd!='S')){
     else{
     printf("\n\rBlocco: ");
#else
#else
      address = (address<<8)+get_int();
#endif}
    if(cmd=='L'){
     unsigned int i;
     unsigned int n=4;
         printf("\r\n");
    if(cmd=='S'){
     unsigned int i;
     unsigned int n=4;
         for(i=0; i<n; i++){
         value[i]=gethex();}
          printf("\r\n");
    if(cmd=='T'){
     int i;
     unsigned int8 a;
     int n_byte_letti=4;
       printf("\r\n");
       printf("\r\n");
       printf(" ");
     printf("\r\n");
     } while(true);
PostPosted: Sun Nov 22, 2009 5:03 pm     Reply with quote
My advice is to simplify your program. Cut out large sections of your
code and make it smaller. Test each little piece of the program.
Prove that it works. Then put it together again.
nemero16
PostPosted: Sun Nov 22, 2009 5:09 pm     Reply with quote
But the program works and also good ... it's just that I want to insert the address in decimal and not hex ... the part to change, or insert the get_int () is this:
   init_ext_eeprom();
   do {
      do {
         cmd=getc();
         cmd=toupper(cmd);
         putc(cmd);
     else{
      address = gethex();
#else
      address = gethex();
#else
#endif}
PostPosted: Sun Nov 22, 2009 5:14 pm     Reply with quote
address = gethex();
#else
address = gethex();
#else
#endif}
Decide which line you want to use, and get rid of all the other lines,
and get rid of all the #if, #ifdef, #else, and #endif lines.
And change the line to address = get_int();
nemero16
PostPosted: Sun Nov 22, 2009 5:57 pm     Reply with quote
ok, I removed everything and I left this:
   if ((cmd = 'L') & & (cmd = 'S')) {
     else {
     printf ( "\ n \ rBlocco:");
     address = gethex();}
but when I go to write address = get_int () the program crashes and does not go forward .. I should set it first receives the value in decimal and then convert it to hex ...how can I do?
Goto page 1, 2  Next
Page 1 of 2
