How do I use #ID to write an ID to a chip?
#ID 0x1234
#ID "serial.num" : Is that means When I write ID to a chip the program find serial number in file "serial.num" and write into it?
#ID CHECHNUM
Where did ID number locate? in EEPROM or special location like configuration memory 2007h.
How do I read this id?
Any concern for this question I appreciate here in advance.
Posted: Mon Nov 16, 2009 2:39 pm
Post your PIC.
cchappyboy
Posted: Mon Nov 16, 2009 3:58 pm
that is pic16f876
Posted: Mon Nov 16, 2009 4:19 pm
The 16F876 data sheet says this:
12.16 ID Locations
Four memory locations (2000h - 2003h) are designated
as ID locations, where the user can store checksum or
other code identification numbers. These locations are
not accessible during normal execution, but are readable
and writable during program/verify. It is recommended
that only the 4 Least Significant bits of the ID
location are used.
