18f46j50 library
giustraman
18f46j50 library
PostPosted: Fri Nov 13, 2009 9:00 am     Reply with quote
Could anyone give me 18f46j50 library?? In my 4.057 PCWHD Compiler there isn't it... Best regards.
PostPosted: Fri Nov 13, 2009 10:59 am     Reply with quote
From the 'CCS Forum Policy and Guidelines' topic:
10. Don't post the CCS example code or drivers, or ask for such code and drivers.
CCS examples and drivers that are included with the compiler are only available to licensed CCS users. If you are missing a driver or example that probably means your compiler is out of date, download or purchase the latest version. Please do NOT copy this code into the forums. You MAY #include such files in any libraries or examples that you wish to share.
This includes header files for devices (example 18f452.h). If you are missing this header file that means your compiler does not support it! Upgrade your compiler.
In short: We are not allowed to send you these files. Even when we do these files will be useless to you because you also need the new compiler version (the files only contain defines, not understood by your version). This is the very reason why CCS sells Software Maintenance (and how they make a living).
